Nov 11, 2020 22:43:17 GMT
if you wind a long bolt though the bridge mounts you can push them out and reset them. only do it once though. the reaction will be silicone in the wood, it sucks. sand it, sand it and sand it some more. apply a sealer then leave each layer to completely cure before the next. normally you'd fit the hardware after you've fitted the neck so you can make sure it all lines up, the kits can be a bit hit and miss on that. how tight is the neck pocket? you might have to shim it to get a nice snug fit. otherwise, looking good. I didn't realise I had to earth one of the pots to the bridge! I'm going to have to get it out using your bolt trick 😔 So wind a long bolt in until it's hitting the wood below sand keep winding and it should push it out?
Nov 11, 2020 22:45:00 GMT
The wiring diagram that came with it doesn't seem to match the colours of the wires it's supplied with. It also says 'nude' a lot... 😂 Edit.. Right, I've had another ganders and I think I've worked out the majority of the wiring. I just need to take the bushing out.
Nov 15, 2020 13:02:27 GMT
Well it's not figured out yet but I'm nearly there 😂 I think I'll use the diagram you posted!
Nov 15, 2020 13:07:23 GMT
The more I looked at it hanging on the wall, the more i started to dislike the finish. I hadn't sanded the red off enough and I wash trying to sand the blue but uncovered the red in various areas. This made it look inconsistent and without purpose (in my eyes). I decided to flat it again and stain it with the idea of giving it a sunburst feel. I stained it fully and then hit it with 0000 wire wool in certain areas. It's made it super smooth to the touch and I much prefer the finish now. Might tweak it a little over the next few weeks as I stare at it on the holder 😂 There are a few bits that might need a bit of 'feathering'.
Nov 15, 2020 13:11:00 GMT
Nov 15, 2020 13:13:57 GMT
Countersunk the holes so I could hit it with the 10mm bit. Unfortunately, I went through from the back on the first one and have damaged the finish.
Nov 15, 2020 13:15:24 GMT
Bottom right peg. Bigger washers to hide it?
Nov 15, 2020 13:55:16 GMT
I'm hoping that when you said measure up you measured from nut to 12th fret then put the neck in the guitar and made sure it matched between saddle and 12th fret. Otherwise, whoopsy. 😂 Nail polish will sort that little whoopsy on the headstock.
Liking the burst, working with stains can be a steep learning curve.
Wiring a 4 pot is straight forward once you've done it once. 😁 don't forget to line your control pockets to isolate them from interference. I'm cheap so I use aluminium tape.
Nov 15, 2020 14:07:46 GMT
Heres the last kit I built. One if thomanns harley benton kits but very heavily modified. Used the same stains as you but i went black and blue burst. Novocaines tele on insta
ChrisT
Club RR Member Number: 225
Nov 15, 2020 14:12:12 GMT
Nice work, shame about the headstock, was going to say touch up pen but nail varnish would work as well, it'll be hidden a bit by the string anyway....
Nov 15, 2020 14:22:26 GMT
I'm hoping that when you said measure up you measured from nut to 12th fret then put the neck in the guitar and made sure it matched between saddle and 12th fret. Otherwise, whoopsy. 😂 Nail polish will sort that little whoopsy on the headstock. Liking the burst, working with stains can be a steep learning curve. Wiring a 4 pot is straight forward once you've done it once. 😁 don't forget to line your control pockets to isolate them from interference. I'm cheap so I use aluminium tape. I basically cut enough off to match the original neck. I could've just rounded the edges but then the neck would've been too long. I'm hoping it's close enough and the saddles will take up any differences. I got it as close to the original one as I could. Although I do think it'll probably be out a bit as the original neck doesn't appear to measure perfectly. We'll see I guess. If I can't get the intonation right, worst case scenario is I take a bit more off.
Nov 15, 2020 14:35:30 GMT
Nice work, shame about the headstock, was going to say touch up pen but nail varnish would work as well, it'll be hidden a bit by the string anyway.... Thanks, mate! Nail varnish is a good shout 👍
Nov 24, 2020 17:00:00 GMT
Nov 24, 2020 17:03:33 GMT
that'll do it. getting there now, you can nearly smell the finish line, it smells like teen spirit. those frets are going to need some work. rather tall and sharp in the edges.
Nov 25, 2020 12:18:13 GMT
that'll do it. getting there now, you can nearly smell the finish line, it smells like teen spirit. those frets are going to need some work. rather tall and sharp in the edges. Yes they're definately sharp at the edges and I was meaning to look up some good guides on how to sort it - any suggestions?
Nov 25, 2020 18:04:12 GMT
crimson guitars have a good guide on youtube. I've used a decent size straight sided needle file with a rounded safe edge for years, then someone bought me a radiused fret file. both work well although you have more control with the needle file to make the fret the shape you want. first thing you'll need to do is make sure the the neck is flat using pair of stand offs the same height in the first and and 12th or above frets and a straight edge to check the neck is flat before you start to try and make the frets level. there is a thing called a notched straight edge, much like the fret file it's something I've never bothered with but could see the merit if you made a lot of necks. once you are sure the neck is flat level the frets with a leveling beam (I use a bit of hardwood with a planed face and a bit of 120 grit glued to it). you could skip this step if they aren't to tall. then you do really need a fret rocker to check the frets and mark the high spots. deal with the high spots and keep checking and marking. if you are using a straight file you'll need to shape the frets, worth watching Bens video on that at crimson. then it's a matter of rounding the ends and you are golden.
That looks the nuts mate, very nice
