Having a few electrical issues , random lighting works one moment then not the next . The reversing lights one worked in the time I went to halfrauds and back neither would worked. Hazards work fine flash flash etc Indication zero or sometimes stay illuminated No high beam flash but one works on selection No horn but haven’t looked at that yet . Any ideas where to look 👀 test
Last Edit: Oct 3, 2020 21:11:34 GMT by sideways1
vulgalour
Club RR Member Number: 146
Can you tell what it is yet? vulgalour
@vulgalour
Club Retro Rides Member 146
Check every earth connection you can get to, sounds like poor connections. Indicators might be down to a duff relay, that's probably an aluminium bodied thing up under the dashboard somewhere (guessing based on similar era cars, I don't know these cars first hand). No high beam flash probably down to corroded connections in the stalk mechanism, horns could be the same thing, or a duff relay.
Looks like a nice starting point, and not that scruffy considering it's a bush find. Someone out there can probably use those Granada wheel trims too.
shin2chin
Red ht leads add 10bhp. Fact
vanpeebles
I am eastbound in pursuit of a white Lamborghini, this is not a recording.
The covered car is smiling at the new arrival!!
[mention]vanpeebles [/mention] the car smiling is a ?
Today I think weather stops playing but I will give it a drive around my area obviously putting on my insurance first
That looks quite tidy, especially when you consider that it's been living in a tree.
Jaguar S-Type 3.0 SE
That looks quite tidy, especially when you consider that it's been living in a tree. The Downside roof is the worst hit and gutter around boot area . Upside it’s solid in all mot hotspots .
Hi anyone have a clue as to which auto box fluid is needed. It has borg Warner 45
Driven 2 miles box changed well 🏴🏴🏴☝️
vanpeebles
[mention]vanpeebles [/mention] the car smiling is a ? The cover has eyes and a smile!
Does anyone know where I can source a some outriggers to repair small area
Tucked away in a warm dry place allowing electrical systems time to dry out properly
Oct 13, 2020 15:59:19 GMT
I've fancied one of these for years.
