fraudownersclub
Club RR Member Number: 23
1987 ford sierra v8 fraudownersclub
@fraudownersclub
Club Retro Rides Member 23
Aug 15, 2020 10:22:27 GMT
I run a set of 9” x17” in the gold all round with 245/45/17 on the rear 225/40/17 on the front with toyo 888 Got another set of the team dynamics which are 9” on the rear and 8” on the front running 235/45/17 rear 225/45/17 fronts on nankang nsr2’s And my hockenheims are 8” alround with 225/45/17 also running nankang nsr2’s 👍. And of course am also running coil overs 😎 ps also running 3mm camber shims
#fraudownersclub #richartsltd
Cool car. With the potential it’s got to go sideways a quick rack is a must.
fraudownersclub
@fraudownersclub
Aug 17, 2020 21:05:41 GMT
Cool car. With the potential it’s got to go sideways a quick rack is a must. Using non power rack at the mo 👍
fraudownersclub
@fraudownersclub
Just found these Was after a launch at the pod 2018. Wooops😂
Sept 6, 2020 10:25:43 GMT
Was originally Dan Thorns car.
Sept 6, 2020 10:27:31 GMT
Sorry should have been a question not statement.
v8
Sept 6, 2020 11:35:39 GMT
Just found these Was after a launch at the pod 2018. Wooops😂 Are you using 7" or 7.5" diff and shafts mate? What times did you run ?
Sept 6, 2020 12:13:11 GMT
fraudownersclub
@fraudownersclub
Sept 6, 2020 15:39:27 GMT
Just found these Was after a launch at the pod 2018. Wooops😂 Are you using 7" or 7.5" diff and shafts mate? What times did you run ? On 7inch 3.92 Lsd pumped up on 100mm lobros. Was running on the 9” rear wheels and Toyo 888 so had plenty of grip 😂 Replaced with new shafts Run 13.5 seconds as my best run. Replaced the rear diff for drag racing to a 4.17 7/2 Granada diff but never got to try it out properly. Now use a 7” plated 3.6 for everyday use
fraudownersclub
@fraudownersclub
Sept 6, 2020 15:41:42 GMT
Was originally Dan Thorns car. I bought this off dan as a unregistered rolling shell in 2016 😎👍
v8
Sept 6, 2020 17:17:31 GMT
Bit of a pain to swap over to 108mm joints and Cosworth driveshafts I suppose, I don't know if the bigger parts would fit the 7 inch diff.
fraudownersclub
@fraudownersclub
Sept 6, 2020 20:11:53 GMT
They are interchangeable you just got to swap flanges both end to use the bigger shaft. I put brand new shafts and lobros from JR on the internet and have got a new set as spares 👍
fraudownersclub
@fraudownersclub
Sept 25, 2020 5:27:54 GMT
Early morning on the way to brands Hatch for ford power live 😎
Sept 29, 2020 6:07:25 GMT
Great car!👍
fraudownersclub
@fraudownersclub
Oct 25, 2020 10:37:08 GMT
Retro rides gathering 2019. Thanks to capture your car photography for some great pictures
Superb "q" car. Brings to mind my favourite expression, "walk softly but carry a big stick"
Oct 29, 2020 13:17:42 GMT
Amazing car and build
