Hi thanks for looking, your car looks awsome. How much are you after for the pump thanks Hah. You jest! I'm getting sick of her being Christmas coloured! As for the pump, it would cost more than it's worth to ship it from here I think. Although if you run out of options over there, then let me know. It came out of a running car but I have no idea what condition it's in, I just grabbed it because mines a little noisy and I was removing the head off the other car so it wasn't much extra work. Was more just to confirm that it was the same as yours and would open up more options. The 18/22R engines also share a few parts so check out old Hilux pumps maybe?
C-rock
Got one of these today ....yes sad I know lol
C-rock
Had to order 4 new lights as these front ones have blown
Like the tax, where did you get it I would like one for my moggy.
C-rock
Like the tax, where did you get it I would like one for my moggy. Ebay £4
C-rock
Strange wheel pcd 5x114.3 Although I am tempted to fit these ....
TessierAshpool
Club RR Member Number: 168
1976 toyota CROWN super saloonTessierAshpool
@tessierashpool
Club Retro Rides Member 168
5x114.3 is pretty standard for a lot of Japanese cars (Honda, Toyota, Nissan, Mazda as far as I know), so you should find wheels easy enough.
Same size on my Supra, what diameter etc. are you looking for?
5x114.3 is/was also widely used by Ford and Chrysler.
5 x 4.5" or (5 x 114.3mm) is a common pcd on classic american cars Ford and Chrysler.
Saw this for sale all over facebook. What happened?
Citroen HY 1962 Toyota CROWN MS75 1972 Toyoya CROWN MS75 1973 Toyota CROWN MS67 1972 Toyota CROWN RS56 1968 Toyota CROWN MS57 1969 Datsun 120a coupe 1975 VW LT31 1995 Volvo XC70 cross country 2007
C-rock
Saw this for sale all over facebook. What happened? Awsome car but change of plans Something has to go and it's this old girl even though I may regret it
ovimor
North East
...It'll be ME!
SpongeBob burger 'flippery' eh? OVIMOR
Knowledge is to know a Tomato is a 'fruit' - Wisdom, on the other hand, is knowing not to put it in a 'fruit salad'!
C-rock
Few more pics of her
C-rock
C-rock
The old factory underseal starting to peel off the sills not will need to treat them and paint them again
C-rock
Carb off time for a strip down
C-rock
So ... stripped the carb down today All clean no dirt or gunge in there But I did find the metal pipe that goes from the brake servo to the carb was loose and the thread does not tighten up...maybe why it's running lumpy drawing in air from there. And found this so maybe it's set to rich and not lean enough ...we will soon find out
C-rock
Can you do me a favour and measure arch to arch and also the diameter across the bottom of the arch and then height to the top (if that makes sense?) Curious to know if I could get that long lower trim and arch trims to fit on the Cressida..
C-rock
Very retro
