Feb 25, 2020 19:16:01 GMT
Tester will test as presented, so rock up with a motorhome and it's a class 4. The transit forum has the process you need to go through to get reclassified as a motorhome on the logbook as a sticky. not if its over 3.5t, still needs to go to a VOSA or ATF hgv station. It doesn't it needs to go to a station capable of testing a vehicle of that weight, it will still be tested as a class 4
Feb 25, 2020 22:09:13 GMT
not if its over 3.5t, still needs to go to a VOSA or ATF hgv station. It doesn't it needs to go to a station capable of testing a vehicle of that weight which is a hgv/psv testing station...
Last Edit: Feb 25, 2020 22:09:43 GMT by welshpug
Phil H
Club RR Member Number: 133
It doesn't it needs to go to a station capable of testing a vehicle of that weight which is a hgv/psv testing station... ...which also does class 4 - and not all of them do.
