Fungus
Dec 27, 2019 23:59:29 GMT
Hi,
I'm looking to put a modern twincam engine and 5/6 speed gearbox in my midget.
Obvious choice is MX5, but the engines are on the heavy side being an iron block.
Any ideas for all alloy twincam engine that is readily available?
Thanks.
MG Midget engine choices ChasR
@chasr
Club Retro Rides Member 170
MX-5 would still be my choice. It would probably be as light if not lighter than an MG Midget engine depending on the flavour you have. In turn, the balance of the car shouldn't change too much and you'll not have to account for brake biases changing and spring rates needing to be played with. I suspect the gearbo tunnel would need work to accept the 5 speed, let alone the 6!
The only other engine I'd consider would be the venerable K-Series. But Frontline, despite being proven with their kits aren't the cheapest, but at least you'll have something which should bolt together fro the best part
IIRC there's a thread on here of a Micra-engined Midget? Engine only, std gearbox, I think
In these PC days, are we still allowed to call it a Midget?
@chasr
i don't think the Sigma engines (1.4 to 1.7) will fit onto a Type 9 without an adaptor being made up. Retro Ford made do something off-the-shelf, unless you have the patience to make an adaptor to fit the engine in.
That or a Mazda 'box may fit on.
The biggest problem with the Sigma engine would be an ECU. From the factory, they come with the immobiliser. Obviously, you can sort this out by getting the key with the chip inside it taped to the key's receiver and bury it somewhere in the car, but that is a risk.
EFI ECUs can add a cost element to things, albeit the inlet manifold, injectors, coil pack etc. would all be there to go, so as to work with an ECU.
Another way would be to get a Zetec 1.8 or 2.0, with a Type 9 and chuck a Weber downdraft onto it with a Nodiz dizzy, albeit those costs may not work out much cheaper than just going with an standalone ECU.
One thing to bear in mind is Type 9 'boxes are not as cheap as they used to be. After all, they're used on a number of 5 speed conversions.
Dec 28, 2019 10:10:15 GMT
Didn't the nc mx5's use what is basically a Ford duratec engine with alloy block?
That could work.
MG Midget engine choices stealthstylz
@stealthstylz
Club Retro Rides Member 174
Dec 28, 2019 12:46:58 GMT
I wouldn't base anything around a Type 9 gearbox, they're a bit curse word really and I often wonder why people use them, the BGH versions are good but IIRC you're into nearly 2 grand for one.
I'd go with a Duratec and MX5 gearbox. The MX5 engines are worth good money but you can spin a FWD one round dead easy and they're cheap as chips, and the 5 speed MX5 gearboxes are cheap. They're ridiculously light (I can easily pick one up off the floor and carry it about). The only downside is the factory piston rings are curse word, but they're cheap to buy and easy enough to rebuild.
93fxdl
Enter your message here...
Dec 28, 2019 15:02:46 GMT
How about a quad cam v6?
Ttfn Glenn
Dec 28, 2019 16:58:13 GMT
I am sure I read somewhere that the Duratec is quite a tall engine so actually fitting it in with some ground clearance might be an issue. An MX-5 lump and box would be first choice for me as there's no need to mess around with adaptor plates - everything is already together and parts are readily available. It's a no brainer for me.
Are KAD 16v heads still available for the A series? Not cheap but possibly easier than a conversion, although it wouldn’t solve the 5 speed ‘box
If you were to keep the a-series, there is also the BMW bike-engine head conversion? And a type-9 gearbox conversion IIRC?
Dec 30, 2019 10:15:52 GMT
elfman
Dec 30, 2019 12:30:25 GMT
Yes the KAD heads are still available but you only get a pocket full of change from £5000 plus you have to sort out the carbs or injection after.. I agree the MX5 engine complete with box is probably the best bet plus reliable and cheaper..
Dec 30, 2019 16:04:53 GMT
Yes the KAD heads are still available but you only get a pocket full of change from £5000 plus you have to sort out the carbs or injection after.. I agree the MX5 engine complete with box is probably the best bet plus reliable and cheaper.. 😳😳😳😳😳
Dec 31, 2019 10:46:36 GMT
How about a Suzuki G13b with a Jimny or Supercarry box. It's all alloy and knocks out 100bhp straight out of the box. Have a look here...... www.ado13.com/dohczuke/dohc.htm
Dec 31, 2019 16:12:56 GMT
Dec 31, 2019 23:30:10 GMT
Some years ago I put a Lotus Eclat engine and 5 speed box in a Sprite. Lots of surgery to fit, but it didn't half go well.
mk2cossie
Club RR Member Number: 77
MG Midget engine choices mk2cossie
@mk2cossie
Club Retro Rides Member 77
How about a quad cam v6? Ttfn Glenn Lots of fab work to fit that, and then BIVA. Which I'm guessing the OP doesn't want Looks a lovely install tho
Ryannn
K-series is the most popular choice for spridgets
Frankenhealey
Club RR Member Number: 15
MG Midget engine choices Frankenhealey
@frankenhealey
Club Retro Rides Member 15
Mazda 13B is another popular option.
