dazq
Kinda New
So a while back I saw a disco 2 with a roof slice to loose the rear hump. Got me thinking , could I use a classic RR LSE roof instead to make life easier? Anyone know if it would be a suitable fit to save lots of messing? This is the look I'm thinking of dl.dropboxusercontent.com/s/g3f6m7a9exp6h38/wagons_disco.pngThanks to littlepixel for the idea :-)
Rich
Club RR Member Number: 160
disco roof swap/chopRich
@foxmcintyre
Club Retro Rides Member 160
Possibly, but not sure if the dimensions on a RR roof will be the same. I know the body framework is supposed to be very similar but isn’t the roof bolted onto a RRC? It’s welded on on a disco. The photoshop looks like a Discovery Sport a la period.
dazq
Kinda New
RR classic roof are held on with hundreds of self tapper type screws! It makes removal quite easy. I believe the Photoshop started life as a pre facelift disco2, chassis are much the same and body frame is close too
I have seen a disco roof grafted onto a rrc, could be done if you leave something to mount to, but what would you do about the rear door?
dazq
Kinda New
I was thinking to modify the rear door to split , similar to how the classic rr were done
It might be easier to see if the rrc split tailgates would fit, i think by trying to separate a one piece door you're opening up a whole can of worms, particularly with the shape of the disco rear screen
dazq
Kinda New
Yes this is very true, my only issue using a rrc tailgate upper and lower is rust! I know you can get alloy repro but they are big money .... :-( A suggestion I had made was to shorten the existing door from top( still keep it hinged) and have a window cut, or see if a std rectangle window could be fitted in its place.
I must be honest the boot door is the hardest one to fathom of the body mods planned, even compared to the slight stretch to the wheelbase to fit the new chassis...
How about a rear door like this?
One piece glassfibre tailgates were available for rrc’s years ago, but i cant remember the last time i saw one
dazcapri
North East
Enter your message here...
Here's how raptors garage did theirs
Mk3 Capri LS
dazq
Kinda New
The door chop looks neat!with some plexi or a bit of custom laminate glass(think the glass is pretty much flat) works well. Although the roof proves a theory , I need something a bit more factory ( ribs n stuff) to look at , maybe use a rrc as a mould start point and chop about to make a grp version ..
The lift up tailgate I suspect would need even more opening room at the shops than the side open door does lol!
bazzateer
Imping along sans Vogue
Remove the hump in the roof? Are you mad?!
dazq
Kinda New
Remove the hump in the roof? Are you mad?! Maybe, but in the image littlepixel did it has been flattened out. I'm not sure if the estate concept will work as well with the hump! Any budding paint shoppers out of there
One piece glassfibre tailgates were available for rrc’s years ago, but i cant remember the last time i saw one The door on the Disco above is actually the original metal door from the vehicle that has been re-engineered to be top-hung. Not a hint of fibreglass about it. :-)
I’d guessed as much, my comment was actually just about the rrc aftermarket tailgates that used to be available, although why you’d want to do away with the split and lose the seat/table/ loading shelf they came with as standard i cant imagine Hope you didn’t think i cant tell a rrc from a disco 😳
andyborris
Seems a lot of work to make a Volvo estate?.....
In the op’s original pic, i think it looks like a cross between a jeep and a subaru forester!
In the op’s original pic, i think it looks like a cross between a jeep and a subaru forester! With more rust and less reliability 😂 (Sorry couldn't resist) The Photoshop actually looks really good, like a pro touring landie
Last Edit: Dec 7, 2019 12:42:58 GMT by joem83
Having said that, have you seen how foresters rust?😳
dazq
Kinda New
The Photoshop actually looks really good, like a pro touring landie This was what I liked about it too, plus I had a suitable 03 plate doner disco and a willing scimitar tax exempt chassis :-)
Last Edit: Dec 9, 2019 1:20:28 GMT by dazq
