Nov 10, 2019 18:49:37 GMT
Evening all Car is actually a p38 rr, but 2.5 diesel Fuel consumption never that good, but is steadily getting worse Fuel computer figures used to hover around the 29mpg mark, but is on a steady downward curve, now registering 27.4, even on a 350 mile trip today, mostly A roads/motorways but all under 3k rpm It has now done 211k, and smokes under load, but ‘they all do that sir’ An I expecting too much, or is the engine dying, or the electronics lying, in a p38? Surely not!😳 Doesn't feel any different to drive, never been exactly land speed material anyway Any ideas? TIA
Nov 10, 2019 19:07:23 GMT
Smoke colour?
Nov 10, 2019 19:34:00 GMT
Blue:blackish Does use oil
Nov 10, 2019 19:43:11 GMT
Turbo on the way out probably, won't help with efficiency but it's never going to be an efficient car to run.
Nov 10, 2019 22:30:37 GMT
Injector nozzles?
Could even try a dose or two of injector cleaner. Works on my old 5 pot Audi which is similar technology. Also, some fuels are better than others and I find that the winter blend reduces mpg a little
Nick
tristanh
Routinely bewildered
Nov 10, 2019 22:43:25 GMT
Cold weather? My 1.9 tdi was noticeably worse on fuel in winter.
check tyre pressures, grease the props, get an ENDTuning chip.
Its supposed to be a hack until i get the daily rrc back up and running, its always smoked, in fact under severe load the road behind disappears! Think ill try the injector cleaner first because (a) its cheap and (b) I'm basically a lazy sod Thanks for help all
Thats still pretty good consumption from a 2.5d p38...amazed you were getting near 30mpg. here is my hit list in order of things to check with the m51 bmw engine
1. Fuel filters- if blocked it will make the performance poor and smoke under load 2. Intercooler Hoses- If split or collapsing under load will make noteable smoke and not perform as well 3. EGR system...clean EGR valve or blank off alltogether 4. Injectors..leak off tests 5. Turbo-piece of cake to change on these engines 6. Run a 60/40 mix of veg of diesel/vegoil through it...cleaned my m51 lump right out and it ran sweet as a nut and much smoother..be aware you will probably need to change filters after a few hundered miles if the fuel system is full of curse word.
m51 is a really simple engine and a doddle to work on
Last Edit: Nov 11, 2019 8:08:16 GMT by grahamk
Nov 11, 2019 18:25:39 GMT
My dad 325tds would only really crack 40MPG on a motorway run for what it is worth.
Last Edit: Nov 11, 2019 18:29:06 GMT by ChasR
Nov 11, 2019 18:41:21 GMT
As well as all the above, it may be something as simple as the brakes dragging or the tyre pressures being a bit low. Checking for overly warm wheels after a run or rusty areas on the discs offer clues without stripping the vehicle. Good luck
Nov 11, 2019 19:49:09 GMT
Turbo oil seal a likely culprit. If you can get a finger in (phnaar) check the radial play on the turbine shaft, also have a look in the intercooler pipework for oil deposits.
time
Nov 17, 2019 21:08:17 GMT
What year is it ? The later ones had an egr that was prone to sticking (Although its easily deleted) Does it start easy when hot ? If it doesn’t your timing is out which will effect economy
There’s also a vacuum pipe under the inlet manifold that Can partially collapse causing smoke and poor fuel economy
Nov 18, 2019 12:41:44 GMT
Its a 1999, on an ‘s’ plate, I've slung a bottle of injector cleaner in it, will await results & report back its got the hot start mod, needs to carry out its self check, but then usually fires up reasonably well ]Thanks for ideas & assistance all
Nov 19, 2019 18:44:43 GMT
Right, i am able to report that it now uses no diesel at all This may be due to the fact that this morning the engine seized solid, fortunately only a couple of miles from home Anybody want a REALLY fuel efficient P38?😁
Nov 19, 2019 22:23:33 GMT
excuse to fit the 335D engine
Right, i am able to report that it now uses no diesel at all This may be due to the fact that this morning the engine seized solid, fortunately only a couple of miles from home Anybody want a REALLY fuel efficient P38?😁 Erm, what "injector cleaner" did you use, for future reference??
It was the lucas stuff, to be fair i don't think thats anything to do with it, the engine started making bearing style noises, although no dash lights came on. I was driving up the side of a river known as the ‘16 foot’ locally, so i was taking it easy because i didn't want to go for a swim, but then the clutch pedal started moving when the throttle was pressed, so the crank must have had HUGE endfloat, and it just died with no warning, and refused to turn over again, so it deffo bottom end related Back to my mk3 escort cabrio then, until the RRC is done
Nov 20, 2019 19:12:02 GMT
Unusual failure....... Somewhat disappointing.
Maybe it’s been chomping on itself for a while and that’s been affecting the mpg......
I use the Toolstation injector cleaner and so far my engine is still turning
Nick
gtste
Nov 20, 2019 20:01:13 GMT
Let me know if you're gonna sell it! Been after a P38 for a while.
