having a bit of a clear out so I have lots of smaller/cheaper early ford parts available.
Pair of pilot rear wishbone tubes only. Brackets on the axle end have been cut off at the weld. Sandblasted and epoxyed, some pitting but nothing really bad. Straight. Approx 56” long. £50pr.
Pair of shoebox front spring hangers for rear springs. The ones that rivet to the chassis. £10.
I have various other small bits like this for shoebox if you need anything specific.
Interior door handle relay and bar, the 3 bolt type that’s ran late 30s- all the way through the forties. I believe the bar is correct length for 38-48 truck. £15.
28/29 model A closed car original hinge pieces, the sections that bolt to the body A pillar. One lower, one upper. Usable condition, not baggy on the holes, although the upper needs the pin extracting. £20 each.
50s Chevy truck column drops. Easy to mod for different applications as they’re pressed steel. £10 each, Ive got a couple.
m
m
