domrr
Looking for a cylinder head from a D6B engine - later model 205 GTI 1.9 engine.
Also late model ECU as well.
Any leads much appreciated as complete heads are seemingly impossible to find!
Thanks
Oct 17, 2019 18:35:29 GMT
ive got loads of ecu,s i will dig them out over the weekend see what ive got
Oct 17, 2019 18:53:31 GMT
what do you mean by late model?
jetronic or motronic?
domrr
dickie12 Thank you! welshpug - I was hoping you'd see this thread as an expert (from what I can see in the forums). The car is a 1.9 detuned cat engine (Gentry/CTI models). I have been led to believe this engine will take the cylinder head from a D6B engine? Sorry but not sure if Jetronic or Motronic but if you can give me a steer on what to look for?
Oct 18, 2019 15:47:29 GMT
look at the ecu casing, you'll find a part number and also the work JETRONIC or MOTRONIC on there, it could be either on the 105 bhp engine and the 122/128 bhp engine as there's a few types even with a cat.
the higher power heads will fit but will give a significant compression ratio increase if its onto a 105 as the piston and chamber design are quite different, in your favour if you want to modify it! but this will need a bigger cam and a mappable ecu.
unusual to need a replacement head really, they can be refurbished, and skimmed quite a bit.
domrr
Oct 18, 2019 16:48:07 GMT
Thanks welshpug. Will look and post findings.
