Sept 24, 2019 16:56:52 GMT
I'm not 100% sure which Corsa's these fit, I have been told "B" and "C". They come with a small bit of electrickary to fit one or the other into a car that's not a Corsa. No idea what these are worth, so make me a sensible offer.. Collection from Hawkhurst, Kent or I can post them at cost.. Having said that, I need to weight them and see how much postage would cost.. (Sorry about the pictures being in a funny order)
Last Edit: Sept 26, 2019 15:19:40 GMT by Stigian
My YouTube Channel www.youtube.com/user/UkWheelHorseBlokeQuote - D'you know, it's people like you, doing totally brilliant and pointless stuff like this that gives me a little hope for humanity
Sept 25, 2019 7:02:19 GMT
The one with the GM/NSK labeled motor is a corsa C Adjustable column (although it doesn't seem to have the ecu with it, lower or upper shaft which are needed to do a conversion)
The Delphi motor one is a Corsa D column.
The controller you have works with the corsa C column, not the D
Sept 26, 2019 15:19:01 GMT
The one with the GM/NSK labeled motor is a corsa C Adjustable column (although it doesn't seem to have the ecu with it, lower or upper shaft which are needed to do a conversion) The Delphi motor one is a Corsa D column. The controller you have works with the corsa C column, not the D Thanks for that Mantasport, you clearly know your columns better than me I was given these units in exchange for a bit of lathe work turning down some pully's. I think they were planned to go on a racing mower but they decided they weighed too much. I shall tweak the title a bit.
Jem45
Sept 29, 2019 19:29:41 GMT
Carbs 'n chrome
