Sept 11, 2019 12:55:28 GMT
Does anyone know of a source for 5-3/4" headlamps with flat lenses? There seem to be plenty of 5-3/4" headlamps, but they are all like bowls. I need both H1 and H4 with sidelight types with a "normal" rather than the fancy "crystal" lens. It's not easy to measure, but I'd say I'm looking for a radius on the lens of about 410mm. Or put another way, about a 6mm gap top and bottom if you had a straight-edge across the lens like so:
Sept 12, 2019 18:12:33 GMT
If you are after a 'normal' light but can lived with a curved glass, I can wholeheartedly recommend the Cibie lights. I have bought and tried a few lamps and with Osram Nightbreakers, they pretty much beat anything Halogen powered in that size. I have a set in my Merc 280SE and night time is not a struggle at all. Even friends who have been in the car at night have been surprised at the light output and that's without me mentioning the lights! One source of flat lens lights may be a BMW E30/E32 & E34. The lights don't look quite so blue in reality ; I'm also still running the sealed beams underneath. I've not really found a reason to go over to the H1s on the bottom yet:
Sept 13, 2019 21:08:17 GMT
Thanks ChasR! I did consider the BMW lamps, but they all seem to have the distinctive "smiley" feature on the inners which I think would look silly on anything other than a BMW. Good call on the Cibies, very good lamps. Too curvy for me sadly
Sept 13, 2019 22:15:46 GMT
Hi, Try Jaguar XJ40 lights.
Colin
Sept 13, 2019 22:41:41 GMT
Thanks ChasR! I did consider the BMW lamps, but they all seem to have the distinctive "smiley" feature on the inners which I think would look silly on anything other than a BMW. Good call on the Cibies, very good lamps. Too curvy for me sadly Smiley is on outers. Interim lights (1987 for E30, 1988-1990 for E34) before they went full smiley were just projector, with a dark centre but reflector elsewhere. Pre-87 E30s have non-projector lights, but they are curved. The smiley, or interim "bullseye", are flat or close enough to satisfy your 6mm ruler rule.
Sept 14, 2019 9:50:53 GMT
Hi, Try Jaguar XJ40 lights. Colin I'll take a look at them, thanks.
Sept 14, 2019 9:52:16 GMT
Thanks ChasR! I did consider the BMW lamps, but they all seem to have the distinctive "smiley" feature on the inners which I think would look silly on anything other than a BMW. Good call on the Cibies, very good lamps. Too curvy for me sadly Smiley is on outers. Interim lights (1987 for E30, 1988-1990 for E34) before they went full smiley were just projector, with a dark centre but reflector elsewhere. Pre-87 E30s have non-projector lights, but they are curved. The smiley, or interim "bullseye", are flat or close enough to satisfy your 6mm ruler rule. Sorry, outers I'll see if I can find some early non-smiley ones. Thanks.
Phil H
Club RR Member Number: 133
Flat(ish) lens 5-3/4" Headlamps?Phil H
@philhoward
Club Retro Rides Member 133
Sept 14, 2019 10:27:37 GMT
I did acquire some flat faced ones many years ago but can’t remember if they were E30 ones or off a Capri?
Sept 14, 2019 22:18:39 GMT
Smiley is on outers. Interim lights (1987 for E30, 1988-1990 for E34) before they went full smiley were just projector, with a dark centre but reflector elsewhere. Pre-87 E30s have non-projector lights, but they are curved. The smiley, or interim "bullseye", are flat or close enough to satisfy your 6mm ruler rule. Sorry, outers I'll see if I can find some early non-smiley ones. Thanks. I'll likely have some of them in my parts box...
Sept 15, 2019 11:03:53 GMT
Ooh, if you see one would you be able to put a straight-edge against it for me and measure the curvature?
Do you know if they are still available new?
Sept 18, 2019 12:02:21 GMT
Bosch and Hella lamps are rather flat, maybe you should have a look at them
MiataMark
Club RR Member Number: 29
Sept 18, 2019 13:52:46 GMT
If you're interested in E30 lights I have a full set (4) that are surplus to requirements. Can't remember if they are 'smiley' or not, away at the moment so can't get photos.
