My Granada coupe with Cosworth BOB engine has an oil pressure sender in the engine block. The dash has a mechanical oil pressure gauge I want to get working again. Key of the matter is I want them both working!
I guess I need some kind of adapter or combination of adapters but have a hard time finding what might be right. The oil pressure sender of the bob is a screw in item and the oil pressure gauge line has a screw on fitting (both ends same as on gauge).
Anyone know the fitting size in the engine block? And of the standard Ford oil line screw on fitting? What type of adapters are available to be able to use both the BOB oil pressure sender and accept the ford line fitting?
Any help appreciated.
