Possibly the wrong bit of the forum given it involves a Hot Wheels car but I'm wondering if anyone knows if this is based on a real car? I'm sure I've seen it before but it may just have been on the concept sketches page of Street Machine years ago. I can't figure out if the base is a Mk10 or not. I bought this one but is comes in other colours too
Last Edit: Aug 4, 2019 3:57:10 GMT by jader1973
1982 Mercedes 280TE
Dez
Club RR Member Number: 34
I think itโs based off the fluevog kustom mk10.
Seems legit
hotwheels.fandom.com/wiki/Fish%27d_%26_Chip%27dNot based on an actual custom but certainly based on the Mk X. I am aware of a small number of Mk X's / 420 G's which are 2 door vehicles but this has been done during work to turn them into convertibles. I'm unaware of a 2 door conversion retaining the steel roof, (but that's not to say it has never happened).
Last Edit: Aug 3, 2019 17:17:43 GMT by MkX
Dez
I have never, ever heard the term โfish and chippedโ or โfished and chippedโ Ever used in the uk hot rod scene.
Iโm pretty sure that is totally made up.
Last Edit: Aug 3, 2019 17:10:04 GMT by Dez
I have never, ever heard the term โfish and chippedโ or โfished and chippedโ Ever used in the uk hot rod scene. Iโm pretty sure that is totally made up. Invoking the power of Google: the only reference to this term in respect of car customising seems to relate specifically to this Hot Wheels model which would appear to back up your claim.
generallee
Well that's fished all over my chips. Next you will be telling us there is no such thing as a custom that changes colour if you run it under a hot tap.
Right, so a bit more fishing about on the interweb turned up a thread ( forum.retro-rides.org/thread/63718/expression-session ) on this very site from 10 years ago which featured this sketch from Australian Street Machine magazine. It is possible that this is where I saw it, and not UK SM. It also has this version In said thread this comment appears, so obviously Fish'd and Chip'd isn't really that new at all HotWheels did a model that was very similar to that first jag - I always assumed it was based on an actual car, but maybe not. Definitely needs to be done, anyway. That thread up there contains a link to another thread about SM, Custom Car etc ( retrorides.proboards.com/thread/59732 ) which contains this image from Steve Kirk's Motorvation on page 11 (of the thread) So maybe I did see it in UK SM years ago before I moved to Australia. Anyway, if you fancy a bit of a look back at the good old days, or some inspiration for your current RR then I suggest you spend a few hours perusing both threads.
1982 Mercedes 280TE
I know there's been quite a few 2 door conversions over the years, but the curves on those panels would make this a 'run away screaming' moment for a lot of people, including me, never mind that roof chop!
Slightly predictably, I have a fish'd and chip'd Jaguar, this one. Having seen pics of 2dr mk10s against 4dr mk10s, 2drs look so good to the point that it makes 4drs look wrong! Its almost as if the door area looks too crowded with 4drs crammed in there. The convertable looks perfect in 2dr form, id love to see a 2dr'd roof'd version for real. Somebody needs to get on it! Its great to see those old motorvation pages, thanks. Helps give the model a bit of background. I'm sure it must have been inspired by those drawings.
Last Edit: Aug 4, 2019 10:39:31 GMT by bmcnut
Having seen pics of 2dr mk10s against 4dr mk10s, 2drs look so good to the point that it makes 4drs look wrong! Its almost as if the door area looks too crowded with 4drs crammed in there. The convertable looks perfect in 2dr form, id love to see a 2dr'd roof'd version for real. Somebody needs to get on it! I'd predict you'd need a double garage to open the door to get out after parking up. Many moons ago I tried putting my Mk X into a standard garage and the door wouldn't open more than a few inches so I couldn't get back out. Very wide car + long, wide doors. Factor in another 9 or 12 inches on the door measurement . . .
Last Edit: Aug 4, 2019 17:56:44 GMT by MkX
Having seen pics of 2dr mk10s against 4dr mk10s, 2drs look so good to the point that it makes 4drs look wrong! Its almost as if the door area looks too crowded with 4drs crammed in there. The convertable looks perfect in 2dr form, id love to see a 2dr'd roof'd version for real. Somebody needs to get on it! I'd predict you'd need a double garage to open the door to get out after parking up. Many moons ago I tried putting my Mk X into a standard garage and the door wouldn't open more than a few inches so I couldn't get back out. Very wide car + long, wide doors. Factor in another 9 or 12 inches on the door measurement . . .ย If someone had the fabrication skills to pull off 2 dooring a mkX then fabbing up a mechanism like the one on a Renault Aventime to allow the doors to open a bit further in the same space shouldn't be too hard, I wouldn't have thought. That man isn't me, so I could be talking out of my back eye.
That's genius! I never knew about the Avantime door hinge tonycocacola
If someone had the fabrication skills to pull off 2 dooring a mkX then fabbing up a mechanism like the one on a Renault Aventime to allow the doors to open a bit further in the same space shouldn't be too hard, I wouldn't have thought. That man isn't me, so I could be talking out of my back eye. Of course, I'm not thinking laterally. All sorts of options available to someone with those high level fabrication skills; modifying to scissor or butterfly doors perhaps?
Last Edit: Aug 5, 2019 11:20:20 GMT by MkX
adam73bgt
Club RR Member Number: 58
Well that's fished all over my chips. Next you will be telling us there is no such thing as a custom that changes colour if you run it under a hot tap. Nah you can still have those if you wish
I think I could put up with this being a 4 dr.
If anyone else posts up anymore pictures like the ones above I think I'm going to do myself a mischeif.
Very interesting, very attractive but a bit too Americanised for my tastes and far too much of the original car lost. Still hoping someone comes up with evidence of a (real) 2 door steel top conversion.
[quote author=" colinhd" source="/post/2527053/thread" Still hoping someone comes up with evidence of a (real) 2 door steel top conversion. Well you have the answer to that one don't you? Out with the angry grinder and MIG ๐
