jamesd1972
Club RR Member Number: 40
So we need to use the flywheel from the 5MB engine (and also therefore a new starter). This engine has been sat unused for a few years so the flywheel is rusty. I've cleaned it up carefully with a pad wheel but are we good to go or do we need to spend 50quid getting it skimmed up properly ? James
jamesd1972
Depends how fussy you are, I'd go with it as it is.
Jul 18, 2019 10:41:39 GMT
I'd just run it as it is. If it had heavy pitting I'd skim it, but it looks pretty good when cleaned up.
Jul 18, 2019 10:41:48 GMT
as it's staying std, leave as is. If you were Turbo'ing it etc, skim it.
slater
Club RR Member Number: 78
Jul 18, 2019 11:42:36 GMT
It will be fine. As long as its not warped skimming isnt really nessicary.
jamesd1972
Jul 18, 2019 11:56:41 GMT
It will be fine. As long as its not warped skimming isnt really nessicary. Warped ?! Bl**dy thing is about 15kg of pig iron not sure what you'd have to do to warp it ! Reason the cushion was on the floor when gently removing it (OK whacking it with a big brass hammer) was so that the floor wasn't damaged ! Thanks. James
colnerov
Jul 18, 2019 13:09:37 GMT
Hi, Yes, I've sent worse round again.
Colin
jamesd1972
Jul 18, 2019 18:50:31 GMT
Job jobbed Thanks for the thoughts people. Some nice 12.9 capheads to hold the clutch on and ready to go. James
