Jun 26, 2019 15:40:10 GMT
I have an Audi 80 cabriolet and I'm think of putting lower profile tyres on a spare set of wheels. The tyres are currently 195/60 15 I'm looking at putting 195/45 15.
Is this going to create a big problem?
slater
Club RR Member Number: 78
Jun 26, 2019 16:07:11 GMT
Well other than lowering the gearing not really.
Jun 26, 2019 16:25:16 GMT
tiresize.com/tyre-size-calculator/This'll help see the gearing difference (it'll accelerate quicker, but be worse on the motorway...) It will also affect ground clearance and arch gap!
Jun 26, 2019 19:56:48 GMT
The bigger question is why you want to make the change?
Jun 27, 2019 21:31:07 GMT
Unless you're going lower it a lot it'll look a bit daft.
Jun 27, 2019 22:59:56 GMT
Unless you're going lower it a lot it'll look a bit daft. This. It will lower the car quite a bit. However, you could argue it can change the scrub radius to it having less, albeit slightly, so the car will behave differently. So it may be a little dartier etc. Personally, I'd stick with the 195/60s. If you want less, profile, go to a 17", where the prices are still sensible in that region. 16" for some reason isn't.
Jun 28, 2019 11:49:33 GMT
I like the look of the lower profile tyres and I also though it would the lower the car without having to mess with the springs.
I have recently bought a second set of audi 80 and thought I could see what the lower profile tyres would be like.
Rich
Club RR Member Number: 160
Jun 28, 2019 17:32:41 GMT
I like the look of the lower profile tyres and I also though it would the lower the car without having to mess with the springs. I have recently bought a second set of audi 80 and thought I could see what the lower profile tyres would be like. It will lower the car by the small amount lost from the sidewall. The effect is visually negated by the wheels looking smaller in the wheel arches however so really isn’t worth doing to ‘lower’ it.
Last Edit: Jun 28, 2019 17:33:14 GMT by Rich
slater
Depends if youre doing it for 'the look' or not. Theres a boat load of technical reason to go for lower profile or reduce wheel size that most people ignore..
I just went from the standard 195/55R16 to 195/50R15 (approx. 1" overall diameter difference) on an R50 Mini Cooper, and immediately noticed improved acceleration, which makes for less 'boggy' pulling out of junctions, etc.
Car also feels more nippy and nimble, with less wheel weight to have to lug about.
The wheels fill the arches quite nicely still, however, I now have to take it slowly going over speed humps or ruts to avoid the dreaded scraping of various bits of bumper trim, etc.
Long story short I need bigger wheels to get lower profile tyres.
Long story short I need bigger wheels to get lower profile tyres. Thats about it, the aim is to keep the rolling diameter close to the same size.
Bear in mind that larger wheels with low-profile tyres generally give you a visual lift, it may look worse with bigger wheels if you aren't lowering to match
Hi-jacking the thread a little bit, its relevant... But i know there are sites that convert different axle gearings to road speed. And sites that convert different tyre size to road speed.
Anyone know of somewhere that can do both at the same time?
Say i changed my axle ratio and my tyre size from stock. I want to know how big the % difference is out, and adjust the tyre/wheel size to get back so my speedo is back to more accurate.
1973 MK1 2600 Capri - Located in Texas 1976 3.0S Capri - X-Pack long term Project 1978 2.0S Capri 1984 Transit County MK2 4x4 LWB 2.5DI 1985 2.8i Special Capri (v8 5.0L) 1986 2.8i Special Capri 1987 280 Turbo Technics Capri 1993 1.8TD P100 - Beater, parts collector 2008 BMW 320i Touring - Daily
