Apr 30, 2020 20:15:54 GMT
Over the winter I put my anorack on to re-create the grille pannel this pre- production vehicle had. A modified panel was required due to the redesigned front of the chassis. Bigger cut outs were required to clear the steering relay arm which was now higher up. For the production models a steel grille was made which eventually found itself fitted to all latter S1 models, but from the pictures, the pre-pro had one based on the early ali panel. The give away is in the head lamp pressing. The one hole grille is what was fitted to production station wagons, the 4 hole grille to all series ones at the time. The prepro grille looks like the one hole steel grille, except has the head lamp pressings of the 4 hole grille. Hope that made sense. So I set about convering the standard ali pannel.
1954 Land Rover 107 Station Wagon 1955 Land Rover 86 Utility 1956 Land Rover 107 Pick Up 1986 2CV 1947 Ransomes Crawler Tractor 2001 C15 Citroen Van 2017 VW crafter
I'd not seen a prototype Landie before. Very rugged looking. Much more so than the series 1. Cool.
First rate work on an important British artifact. John
+Bookmarked. I like the oddness of it. Is that a "tropical roof" on top too?
It is technically a series one, but is the first of the 5 door vehicles. Total long wheel base series one station wagon production only numbered 7,000, with only 254 sold into the UK market over the 3 years it was produced.. As a 10 seat vehicle it attracted car tax, which did not make it popular in the UK.The new chassis design for this vehicle, basically went on to be the design used for series two and three long wheel base vehicles. Ironically these station wagons were the last series one vehicles produced, there manufacture continued 6 months into series two production, whilst tooling was finished for the new series two 5 door station wagon, a much more refined vehicle and was also classed as a 12 seat vehicle despite there bing no more room inside, which then avoided the car tax problem as it was then classed as a bus. Series 3 station wagon for comparison. This one was used on the shoot at the farm I worked at, hence the flotation tyres. Yes the extra panel on the roof is a tropical roof. There are openable vents under it to let the air through. They actually work quite well.
So to continue with the grille modification: All the spot welds were drilled out so that the brackets that support the radiator could be removed. Then working on the new cutouts I cut away the excess metal and made a plywood former to get the new shape. Here you see one side done. Both sides done and the centre strut cut out. I have already rolled the LHS in, just the right to do. I now need to build a reinforcement piece to go behind the grille. I am not sure how this would have been done originally, but I have largly followed how it was done on the production steel pannel.
First I had to linish off the strengthening from the original pressing.
The steel version is made out of three seperate sections, but to maintain strength I decided to make mine in one piece. These sections have a reputation of cracking at the best of times, which is why the steel version was adopted on all latter series one vehicles. So there was much playing with paper templates wooden formers and a bit of ali.
In the last shot above it is nearly finished, just the edges to trip up. Whilst making it, it was a suprise as to how much the metal spang as it was being formed. The whole think bowed like a banana once I had removed the former, so I had to bend it all back into shape, as a result the edges arn't as tight to the outside edge of the grille pannel as I would have liked, but I have never tried anything like this before, so was happy with my first effort - no one can see it anyway! Next was to bond it in with Sikafix. then cut two pieces to infill the holes, which were again bonded in. Then reunite it with the radiator mounting section. I have again bonded this with the addition of a few aluminium dowls I have countersunk in. Fingers crossed this will be sufficient to hold the weight. I finally gave it a skim of filler profiled it and gave it a coat of etch primer. The primer has highlighted a couple of areas that need some attention, nothing drastic, just a bit of sanding and stopping, before I put on a couple of coats of high build primer and flat it off
Last Edit: May 1, 2020 13:51:02 GMT by landieles
Cracking job!
Fantastic to see this rebuild. I do love these Station Wagons and seeing a prototype with the subtle differences is fascinating. Bookmarked 🙂
great work, I think gluing and riveting is about the only way to repair birmabright, I tried tigging my 1960 s2 it was a mess, there just seems to be too many impurities in it to weld.
great work, I think gluing and riveting is about the only way to repair birmabright, I tried tigging my 1960 s2 it was a mess, there just seems to be too many impurities in it to weld. I have some one looking at my wings just now so we will see how they get on. I could buy a whole new repro set for £1200, which is the way a lot of people would go, but I prefer to retain the originals where I can, I also think you can repair properly for less than that sort of money. Some people with deep pockets take the easy way out.
Great work.
If welding those cracks doesn't work, would you consider a backside patch adhered with Sikaflex, then a tiny bit of filler, or would that be too much of a bodge?
Hopefully the welding does work.
John
Thats what I ended up doing, blasted the area behind until it was spotless, feathered the edge of the hole, used a modern panel adhesive (smelt like it was epoxy based) to bond new metal in from behind, then used alloy based filler to finish it off.
Great work. If welding those cracks doesn't work, would you consider a backside patch adhered with Sikaflex, then a tiny bit of filler, or would that be too much of a bodge? Hopefully the welding does work. John I have done that in the past, but it always seems to crack out eventually. I hope this guy can sort it because these holes are the tip of the ice berg. I think because Land Rovers have flat bodywork, people cant resist drilling holes and adding bits.
Over the last couple of months the front wings have been welded up, In some places aluminium cut out and new put in, in others holes just filled. you can see the results in the photos. not pretty, but it is at least solid and stable, so a skim of filler has been required. Numerous hours of applying, sanding and repeating the process, fairly happy with it now and will see what it looks like after some coats of filler. IMG_2626 This wing had a whole new end made up and welded on. After creating a ton of dust, we are here. The inner wings were badly corroded and broken, so being basically flat I decided to make my own replacements. This started with drilling out all the spot welds and rivets, to separate it from the wing top. I'm lucky enough to have access to a guillotine and bender. Which is helpful. Pleased with the result. Having done all this I wanted to check it all fitted back together, so have done a dry build just using nuts and bolts. A lot of the wing will eventually be held together by rivets or bonded in place of spot welds. On the new ally, I will create some fake spot welds . [/url The fit hasn't been too bad, some tweeking and elongating of holes where the ali has distorted and pulled. Before spraying I did a trial fit to the vehicle, getting these aligned is always a nightmare as there are so many variables. To get this stage I had to reposition the bulkhead and do a bit of tweeking. When comparing to the factory photo the panel fit doesn't look too bad, although I do want to get the wing fronts straight and level, it really bugs me when I see vehicles with wonky wing fronts.
Congratulations on your determination to preserve such an iconic vehicle. Looking forward to seeing the various stages of progress and the ultimate end result.
I'd missed this one.
Not any more!
Great work and interesting back-story.
What a lovely & interesting old Land Rover. Carry on the good work!
Aug 23, 2020 16:59:02 GMT
I'd missed this one. Not any more! Great work and interesting back-story. Me too. Bookmarked now though. 👍👍
PHUQ
Aug 27, 2020 11:54:28 GMT
I remember seeing this featured in one of the Landy mags waaay back when, I guess when it was first "discovered", I recall the extra headlight bowls in the wing fronts and the reference to boat launching!
Great to see it coming back to life, what a remarkable survivor. Looks like you've managed to retain a lot more original material than you'd expect too.
