RB20det Engine owned by me for 3 years, always used and maintained well.
Performance Spec -
550cc Denso Injectors
top mount t28 turbo manifold
near new mint cond Holset HX32
Custom braided turbo oil lines
38mm genuine Tial external wastegate
v band 3” downpipe
z32 MAF
Near new genuine splitfire coilpacks
Iridium 8 spark plugs
K&N air filter
Near new coilpack loom
Nistune ECU (Rev limit at a very safe 7600rpm)
1.5bar boost, mapped by Abbey Motorsport - 350bhp @ flywheel
In 2018 I stripped it down and fitted new gaskets, new oem piston rings, new cam belt, new stem seals, lapped valves, new cometic MLS metal head gasket, had the cyclometer head decked, new oem head bolts etc
Not included, but the car uses a 255 walbro fuel pump, and I have an AFR sensor and gauge. I’ve always been careful to monitor running temps and AFRs. Engine has been well maintained with regular oil and filter changes. I also use an oil cooler with thermostatic plate (not included in sale)
Engine will come with ancillaries, p/s pump, water pump, alternator, manifolds etc. Can also include viscous fan (I used electric fans)
Can negotiate less or more parts depending what’s needed for buyers car
The engine is awesome, pulls great and is genuinely fast! I’ve used it every week since buying it in 2016. It’s had a lot of road miles and seen some track days too. Never let me down and only been apart for preventative maintanance.
£2500 for the above package, but prepared to sell stuff separately if need be.
Located in Essex. Happy to pallet for delivery.
Still in the car so can be heard running etc. Comp test the other day was 155-170psi on all cylinders cold
Hill Climb Rb20det VIDEO - CLICK HERE
Performance Spec -
v band 3” downpipe
z32 MAF
K&N air filter
