cruez
May 19, 2019 18:14:46 GMT
Anyone an idea what car this rear window louver / sunblind / visor or how it's called, is from? no number or brandname on it. Thx in advance! 90 cm wide top 100 cm wide low 55 cm height
Last Edit: May 19, 2019 18:15:25 GMT by cruez
cruez
Jun 13, 2019 20:23:42 GMT
Nobody?
Jun 13, 2019 20:33:13 GMT
No idea really, but a pic from the side might be helpful to narrow down to cars with a rather upright rear window - or flat ones. These blinds usually let you look through from the inside, so the angle of those louvers could give a hint?
cruez
Jun 15, 2019 11:44:25 GMT
No idea really, but a pic from the side might be helpful to narrow down to cars with a rather upright rear window - or flat ones. These blinds usually let you look through from the inside, so the angle of those louvers could give a hint? Yes thatโs a good idea. Will do this this afternoon. The odd thing is if you look the internet, you never find one in this shape. (The sides of the horizontal bars hanging loose ) mostly you have a rectangular frame with bigger horizontal bars) Grts.
cruez
Jun 15, 2019 16:48:38 GMT
cruez
Jun 15, 2019 16:51:08 GMT
cruez
Jun 15, 2019 16:52:00 GMT
cruez
Jun 15, 2019 16:54:53 GMT
I suppose its a europ car. As you can see on detail fotos. Top slides under the window rubber. Under has 2 mounting points. Also 2 litle holes. But may be drilled afterwards.
Jun 15, 2019 17:41:52 GMT
Guessing that for maximal visibilty in the rear view mirror these slats would have to be level, I did a little rotation to your pic. First cars to come into my mind would be golf mk1 or 2 or peugeot 205. But I have no idea if these cars would match the given measures. Good luck with that riddle.
cruez
Jun 17, 2019 18:44:50 GMT
Guessing that for maximal visibilty in the rear view mirror these slats would have to be level, I did a little rotation to your pic. First cars to come into my mind would be golf mk1 or 2 or peugeot 205. But I have no idea if these cars would match the given measures. Good luck with that riddle. First thought also was a mk1 golf. Have to ask someone with one to measure. The window has to be flat as the louvre also is... 205 has a curved rear window. Grts
cruez
I think i found it!
Golf mk1
cruez
What do you guys think?
Last Edit: Jul 3, 2019 7:25:56 GMT by cruez
Now you need to find someone with a mk1 Golf to try it on๐
