So, I'm looking at options for upgrading the turbo for my Uno Turbo-engined X1/9. Using the formulae in Garrett's guide I've worked out some rough numbers for airflow and boost ratio at the desired peak power and peak torque, but I'm struggling to find a turbo that fits the application (turns out not many people go for high boost low flow 1.3l engines...who knew?). I've been relatively conservative for the volumetric efficiency at 85%, but probably been a little optimistic with intake temps. The figures I'm looking for are: 1. 180bhp, 2.4 pressure ratio (1.2bar boost), 19lb/min airflow at peak power (6500rpm), 12lb/min at peak torque (4000rpm) 2. 200bhp, 2.7 pressure ratio (1.5bar boost), 21lb/min airflow at peak power (6500rpm), 13lb/min at peak torque (4000rpm) 3. 230bhp, 3.1 pressure ratio (1.8bar boost), 24lb/min airflow at peak power (6500rpm), 15lb/min at peak torque (4000rpm) So far, I've only been able to find a handful of turbos that work for options 1 and 2. Interestingly, none of the recommended upgrades for Uno Turbos seem to fit well with the requirements. The commonly recommended T25 doesn't seem to fit in any configuration. Only the T25 60 trim 0.48 A/R works with better volumetric efficiency (fits with the advice that these engines need porting before they can make good power). The GT2554R used in this thread also seems like a poor fit, and likely works mainly by driving the peak torque (and boost in general) higher up the rev-range so it doesn't surge lower down. The only turbo I can find that seems like a good fit for options 1 and 2 is the T3 45 trim: So, here are the questions: 1. Do people think that a T3 45 trim would have a slow spool on a 1.3l engine? 2. If it is slow to spool, would that be due to the turbine geometry? If so, does anyone know of any established hybrid setups that might give a faster spool? 3. Does anyone know if changing the turbine specs will affect the compressor map? 4. Can anyone teach me a bit about how the various specs of a compressor wheel affect the compressor map? Ideally I'm looking for a turbo that's capable of relatively high boost but with low flow.
I've done a little more research today, and apparently there are things called surge ports or MWEs (Map Width Extenders) that are machined into housings to help with low-flow/high-boost surge. They're the little ports in the housing on this: What they do is allow boost to bleed from the back end of the compressor into the front again, recirculating the flow and reducing the amount a turbo has to compress the air (as some of it is already a bit compressed). Housings with these are readily available for sodding great turbos like Holsets or GT35s, but I haven't seen any for something suited to a 1.3l engine yet... I've also been doing some very rough mapping and come up with these: These maps are for a few T3s which is one of the only turbos that seems to fit most of the requirements relatively comfortably. I've done maps for 85%, 90% and 95% VE. The green line is for the minimum power I want to make (180bhp), the red line is for a hopeful figure (200bhp), and the blue line is where I'd really like to be (230bhp). The calculations are pretty crude, and are based on making peak boost by 4000rpm. Not sure how laggy a typical T3's going to be on a 1.3l Uno Turbo engine, but for low-rpm surge that might actually be a good thing. Not sure... If we compare the green and red lines, doing a bit of porting and intake/exhaust work would help make it more efficient (requires less intercooling which is a good idea for an X1/9), but none of them will really support the 230bhp goal. The 95% VE map comes pretty close, but the turbo just runs out of puff at 6500rpm (with another 500 left to go to redline). Another option seems to be a GT2259 52 trim 0.42A/R: It'll sort the 180bhp figure as-is, but dips into surge at full boost in low-rpm. I don't actually know what this will do, any ideas? Does it just make less boost at that point, or will surging cause damage to the turbo (I'm expecting the latter). If I have a blow-off valve, will that area of surge just cause the blow-off valve to open around 4000rpm at full boost to vent extra flow (if it's set up right)? Either way, it's pretty much the only turbo I've come across that seems to be able to achieve the 230bhp goal. All other turbos I've looked at either surge at low rpm, or are too small and choke at high rpm. 4000rpm peak torque looks like it just dips into surge, but perhaps that's fixable with one of these MWE ported housings... I haven't actually seen any before/after compressor maps for a turbo with and without a ported housing though, so I don't know how they shift the map around. So, I suppose the exam questions are: - If a turbo dips just to the left of the surge line, is that controllable with things like an external dump valve?
- If a turbo dips just to the left of the surge line, does it just lag a bit and not build boost or will it merrily wreck itself by surging?
- Does anyone know what a surge-ported MWE does to a compressor map? I know it extends the surge line. I also know it affects efficiency. IS there some sort of tradeoff between surge width and choke at the top end?
- Anyone have any ideas for other turbos that might be able to produce high boost at low flow without surging? I was thinking about small-displacement diesel turbos, but not sure where to start googling for them.
Should have just stayed with NA tuning. I know what I'm doing there
Click picture for more
I was going to reply yesterday to suggest you plot your desired torque curve on the compressor maps your looking at, but looks like you're way ahead of me! I'd suggest you plot a few more points, ideally every 1000 or 500rpm, for the various boost levels you're thinking of running. This should roughly show your surge margin on the way up to max boost (so from 2-4000 RPM). In OEM engine design, you tend to aim for 10% surge margin, but you can reduce that if you know the car is only every going to be driven at sea level for example. In answer to one of your previous questions, the turbine side has no effect on the compressor map, but will affect the transient response (or spool time). A large turbine on a small compressor may mean you can never reach the upper left hand side of the compressor map as you simply won't have enough flow to spin the turbine to the desired speed at that point. Likewise too small a turbine may mean you end up choking the turbine before reaching your desired flow through the compressor. Realistically this will never be an issue as any off the shelf turbo will have its turbine and compressor fairly well matched. Surge will damage the turbo, specifically it will wear the thrust bearing out. It sounds like classic turbo noises (shtuu tuu tuu!!) but you'll hear it as you're accelerating. Ported housings extend the surge margin in the mid-lower left hand portion of the compressor map (but not the upper left hand part of the map). This is really only advantageous on large high flowing turbos where you want a large range of flow rates with a moderate pressure ratio. Or you have a big turbo and are running a high pressure ratio but want to start spooling it earlier without the risk of surge. See this page for an example of ported and non ported housings: www.turnology.com/tech-stories/power-adders/understanding-compressor-maps-sizing-a-turbocharger/For your application i doubt it will offer much of an advantage - it looks like you want a high pressure ratio but over a fairly small range of flow rates, much like a typical diesel turbo! (as i'm sure you've figured). A diesel turbo will probably be a closer match in terms of compressor flow (they tend to be tall narrow maps - high pressure ratios but fairly low flow rates) but you need to be aware that they cannot withstand the same exhaust gas temperatures. A typical diesel turbine will be designed to cope with around 750 degrees exhaust temperature, a high powered gasoline engine can easily run EGTs of over 1000 degrees (although I doubt an 80's engine would run that hot). If you go down this route I'd suggest you get an EGT probe and you may end up running very rich under high boost to protect the turbine. Or just run it super rich and hope for the best! As for what actual turbo you should use, i've no idea! But you're certainly going about it the right way. I would say a compressor map is a must given you want to run so close to the surge line (and the max speed line in some cases) and you should re-visit the map once the engine is up and running and you can verify your flow rates. I will also say that the T3 frame is probably a bit big, and that the 'T' series turbos in general are a very old design - a GT22 or GT25 would be a better choice. Or there are of course several other manufacturers, Borg Warner (VAG, Porsche), MHI (Mitsubishi, Subaru), IHI (usually on subarus, some toyotas?) etc That turned into a bit of a ramble, but i hope some of it was useful
Thanks guys I'll look up those turbo minis. 200bhp on a 1275 A-Series is bloody impressive. I think what a lot of people seem to do is run big turbos so they can get the flow they need for peak power, and then size the turbine and/or use electronic wizardry to control the boost at lower rpm. I'm sure it's fine, but to me that seems like a way to get a big number and a slow car as you spend most of your acceleration in low-boost. Happy to be proved wrong mind! Good idea Splitty about plotting more points on the map. I've done a crude estimation with a straight line, but as it seems I'm going to be forced to run quite close to the surge line some more accuracy would be good. I'd love to have a 10% margin, but it seems like there's a gap in turbos for what I'm after :S Glad to hear the turbine makes no difference to the compressor map. That means I might be able to get someone to put a diesel compressor onto something like a T25 or GT housing and turbine which might fix both spool and exhaust temps (same goes for a T3). On the topic of diesel turbos I've found this chart for an OEM and uprated turbo from an early '00s Ford Ranger 3.2l I5: If I can get it to spool (maybe see if someone can hybridise it onto a T25/T28 or something) then it might be just what I'm after it's also in Australia which may prove to be somewhat difficult... Oh, and the purple line on the final map is just playing around. If you can get it to flow and keep intake temps reasonable then the uprated turbo might just be able to make 300bhp without surging! A lot of ifs, but it's promising Thanks for explaining the effect of ported housings. I thought they might widen the lower end based on a couple of maps I'd seen. Was kind of hoping they'd widen the top as well I'm guessing it's more like this sort of thing (Borg Warner EFR 6758 with a funky recirculating valve): Shame as otherwise the GT2259 above might be a good option. It might still be an option if someone can tweak a few things to sacrifice flow and increase PR. Also, I have only really been looking at Garretts to date as I know they'll fit on the exhaust manifold I have (or one I can get). The rest also use m3/s for their flow maps which I haven't fathomed out yet. I'll sort that next as there might be some Holsets that look suitable
Oh, the Ford Ranger turbo is a GTB22V in case anyone was wondering. Edit: just read through the Turnology link and perhaps a ported compressor housing is what I want. Here's before and after maps for a ported housing on the same turbo: Non-portedPortedYou can see the efficiency islands have shrunk (as has peak efficiency: 72% before and 70% after). However, it has shifted the map to the left at the top which is what I'm looking for. Very interesting. I wonder whether the placement of surge porting has a big effect on where the map shifts around (would preclude amateur modification if it does). The second map does look pretty similar to the GT2259 I'm looking at so there's a possibility it already has some form of surge porting (although most of the pics I've found suggest not).
So, I thought I'd got it sorted with a boost solenoid to control the boost...but of course that won't solve it entirely.
Thinking about it, reducing the boost at lower rpm will reduce the flow (for a while I was thinking you could magically shift boost downwards and keep flow constant).
So, you can use them to run a big turbo without surging, but it will still be peaky. Opens up some options for me that wouldn't otherwise have worked (GT2056s like that Speedhunters Mini linked, and GT2259s), but for a full-fat torque curve the GT2256VK Ranger turbodiesel compressor map is still looking the favourite.
So, if anyone's still following it turns out that the GTB2256VK from a Ranger is a variable vane turbo. No wonder it's got such a broad spread of efficiency. I wonder if aftermarket ECUs are able to control variable vane turbos...
madwrx
May 11, 2019 23:09:20 GMT
just imo but your looking to get the turbo to do all the work in your tuning strategy-an 8 valve 1.3 engine will already be pushing its limits in exhaust flow much above your lower power goal-the airflow maps are only projections at ideal engine flow rates -cam sizing and good porting will add precious airflow gains at mid and higher rpms -higher cr will help massively with off boost and on load response(actual dayto day response) at the expense of running closer to the det line at higher ict temps- generally picking old school 80s tech in a t3 can only mean a laggy high rpm boost threshold engine- no idea what your budget is like but much better to speak to someone like AET who could spec or build a billet turbo for you to gain response and add top end airflow- a 1275 mini (which are usually someting like 1340cc) will have every trick in the book to achieve 200+ bhp -it takes a pretty special build(race spec virtually) to hold it altogether- for all that pleaseplease post some pics up \
Last Edit: May 11, 2019 23:12:35 GMT by madwrx
