My spider hates me, I have given the engine new belts, pulleys and a tensioner, even rebuilt the variator.
Battery then died, roof packed in and the window stuck.
Roof sorted, battery replaced.
I can hear the o/s window motor clicking so I swapped the switches round and the n/s worked, reckon the switch is ok, it’s a pita but I removed the motor and arms.
Wired the motor up to a battery in the garden, works perfectly, tried it again with a towing bracket and a brake disc hanging off it, works perfectly.
Greased everything up and sprayed silicone on the runners, reinstalled it (bigger pita than removing) connected everything up and ‘bingo’ the window went up beautifully.
Alas that is all it did, we are now back to nothing but a light click from the motor...
Suggestions please.
Suggestions please.
