logicaluk
My acclaim is running a set of yamaha r6 throttle bodies which attach to the original accellerator cable using the bike quadrent the problem i have is the pedal is too sensative at comming off idlle and low openings. I guess i need to buy or make a new quadrent. anyone have any bright ideas. Dan
Last Edit: Apr 6, 2019 21:39:54 GMT by legend
logicaluk
Thank you legend that crystallises several things I had whiring arround the back of my brain. I had assumed there was some ready made ones and i was using all the wrong serch terms. Dan
I normally just move the cable attachment on the pedal nearer the pivot point. The closer to the pivot the less cable movement for a given pedal movement.
First time i ran r1 carbs the pedal was far too sensitive and had a very short range of movement. I halved the distance from pivot to cable attachment and it transformed the cars drivability
that sounds like an easy fix
logicaluk
I normally just move the cable attachment on the pedal nearer the pivot point. The closer to the pivot the less cable movement for a given pedal movement. First time i ran r1 carbs the pedal was far too sensitive and had a very short range of movement. I halved the distance from pivot to cable attachment and it transformed the cars drivability unfortunately the acclaim cable attaches just inside of the bulkhead and full pedal travel opens the butterflys fully. Ive had another look and ill try moving the point at which the outer cable attaches, before making a new quadrent. Dan
