Mar 22, 2019 18:55:20 GMT
Right, quick question. Ive got my t4 caravelle on the road after a 7 year slumber And the aircon is dead, no pressure in it as far as i can tell. Codes come up in vagcom saying so too.
Does anyone know of a cheap/free way to test it? I don't want to spend on getting it charged up just to find its got a dead rad or something, and would realy love aircon for the summer.
Any ideas appriciated, was sorta thinking pressurise the system with air? Or am i way off the mark?
Mar 22, 2019 19:44:16 GMT
simple way is vacuum test , the better way is to use oxygen free nitrogen , as it not only helps find any leaks but also helps dry out the system as it attracts moisture, neither though really is a home job
retired with too many projects!
Mar 22, 2019 19:51:03 GMT
Hi, The correct order for testing is vacuum test, pressure test with OFN (Oxygen free Nitrogen) then evacuate again and fill with refrigerant. You can do a visual inspection for oily/dusty patches, the usual places are the condenser ie. the rad in front of the main water rad and around the front of the compressor. It's not advisable to use air as it contains too much humidity.
Colin
Edit: Implandy beat me to it, must type faster.
Last Edit: Mar 22, 2019 19:52:29 GMT by colnerov
Mar 23, 2019 20:15:07 GMT
So no realy cheap option involving a footpump and huge bodgery ? Haha
Ok guys well guess i better get it booked in somewhere. Cheers for the advice 🙂
oldisbetter
If it has a ECU it's complicated :)
Mar 23, 2019 22:40:33 GMT
We took a motor to Kwikfit and they had an offer on to re gas the air con for about £50 and make it colder or it was free, After about an hour they pointed out the seals were knackered in the pump and charged nothing.
Mar 24, 2019 21:20:08 GMT
We took a motor to Kwikfit and they had an offer on to re gas the air con for about £50 and make it colder or it was free, After about an hour they pointed out the seals were knackered in the pump and charged nothing. Oh thats interesting, might have to try that. Cheers 🙂
I have a mate who is a refrigeration engineer but I don't like to use up all my favours in one go (he does house electrics too) so I had mine done at kwik-fit too. I think it was £45 via an online offer and they refunded it because the compressor was buggered. Full price is £60 but you can usually find discount codes online.
A replacement compressor will be going on mine at some point in the near future. A black car with black leather is not all that nice at the height of summer. I'm going to call on my mate this time.
Jaguar S-Type 3.0 SE
Ryannn
I’ve used Kwik Fit as a budget leak test on two cars. Annoyingly on the most recent they didnt find a leak, but the system was empty again after a couple of weeks. So it’s not always that helpful!
Last Edit: Apr 2, 2019 16:00:43 GMT by Ryannn
