Been trying to fit my windscreen on my 67 beetle but not having much luck.
I have cal look seals. I have managed to get the rear window in but it doesn’t look right and the front has been a nightmare seems the top corners are miles out if I start from the bottom and vice versa.
Any tips on fitting windows? I’m using paracord which is lifting the rubber perfectly and someone on the other side applying pressure.
I really don’t want to use washing up liquid.
1967 Beetle
dreadspeed
1972 triumph 2.5 pi on carbs
have you tried a rubber lubricant instead of washing up liquid
Window fittingDeleted
@Deleted
Has stated above a lubricant will help - WD 40 or anything similar - chances are that the sealing fins within the rubber are preventing the screen & rubber from seating correctly into the aperture
Last Edit: Mar 20, 2019 7:33:11 GMT by Deleted
Mar 20, 2019 17:48:57 GMT
Will regular WD40 be alright or does it have to be a silicon one?
Is it best to apply it to the car or the seal?
1967 Beetle
Mar 20, 2019 18:36:57 GMT
Any, squirt it in the groove and over the seal then wipe off when you're done. I've used furniture polish in the past, cheaper and smells nicer.
Mar 20, 2019 18:54:35 GMT
nothing worse than a dry run.....get her lubed up!
Mar 25, 2019 22:01:04 GMT
some windscreens are worse than others, but i always got the job done by using; two pairs of hands, paracord, and plenty of fairy liquid.
helped a mate re-glaze his 911...it concentrates the mind for sure.
Mar 29, 2019 17:35:20 GMT
Nice one will give it ago with some wd40
Next question how do I remove a window that’s already fitted? The rear window has only been in a couple of weeks but doesn’t look right
1967 Beetle
