Apr 30, 2019 15:27:24 GMT
- get yourself the cartridge type seam sealer that goes in a skeleton gun - (low modulus / MS type - NOT PU / Tigerseal or Skiflex) Grumpy, Do you have a particular brand / type you prefer? I'll be need some of this soon. Cheers.
I do but its a Kent Europe product which is trade account only ordering - just had quick search and Tetrosyl do a similar product which is a low modulus MS type - these take longer to dry but give a more workable result and can be brushed in to replicate a factory seam if required - the PU seam sealers are difficult to work and tend to not flow or brush out neatly further to this it's difficult stuff to keep once you have opened the cartridge - so if you only use a part cartridge - its a bit of a bind to make reusable / use again at a later date - link to the Tetrosyl product that I found below www.amazon.co.uk/CSS310-Tetrosyl-Cartridge-Sealer-310ml/dp/B009LHDA3W
Ritchie
Club RR Member Number: 12
Apr 30, 2019 16:34:40 GMT
Thanks for that! Apologies for the slight thread hijack.
keyring
Club RR Member Number: 47
Apr 30, 2019 19:07:12 GMT
Fair. Play. Wish I could weld like that mate, excellent work! Thanks, I’ve still got a lot to learn I feel, but practise makes perfect and all that... Grumpy, Do you have a particular brand / type you prefer? I'll be need some of this soon. Cheers.
I do but its a Kent Europe product which is trade account only ordering - just had quick search and Tetrosyl do a similar product which is a low modulus MS type - these take longer to dry but give a more workable result and can be brushed in to replicate a factory seam if required - the PU seam sealers are difficult to work and tend to not flow or brush out neatly further to this it's difficult stuff to keep once you have opened the cartridge - so if you only use a part cartridge - its a bit of a bind to make reusable / use again at a later date - link to the Tetrosyl product that I found below www.amazon.co.uk/CSS310-Tetrosyl-Cartridge-Sealer-310ml/dp/B009LHDA3WThanks for that! Apologies for the slight thread hijack. No problem, I was going to have to ask myself to get some ordered
Apr 30, 2019 20:15:15 GMT
Just a quick one chaps - I would highly recommend that you put a quick squirt of primer over any welded / bare metal areas before you apply the seam sealer
keyring
Just a quick one chaps - I would highly recommend that you put a quick squirt of primer over any welded / bare metal areas before you apply the seam sealer Thanks I did that I assume it’s possible to paint over the seam sealer?
Just a quick one chaps - I would highly recommend that you put a quick squirt of primer over any welded / bare metal areas before you apply the seam sealer Thanks I did that I assume it’s possible to paint over the seam sealer? Yes - so long has you have left the sealer long enough to cure - paint over sealer that has not cured and it cracks the surface of the paint open
keyring
Thanks I did that I assume it’s possible to paint over the seam sealer? Yes - so long has you have left the sealer long enough to cure - paint over sealer that has not cured and it cracks the surface of the paint open Excellent, thanks!
