MiataMark
Club RR Member Number: 29
jumpstart connectorMiataMark
@garra
Club Retro Rides Member 29
I've just bought one of the small, lithium battery, jumpstart packs. It has a very short lead to the crocodile (alligator for Americans) clips. Does anybody know of a source of compatible connectors, I'd like to make up some 'fly' leads that I can leave on the car so I can connect chargers, jump leads etc. The connector is this one;
moglite
Club RR Member Number: 144
jumpstart connectormoglite
@moglite
Club Retro Rides Member 144
If your pack is the same connector as mine (looks to be) those are EC5 connectors. Common in the RC world and therefore all over eBay/Amazon etc.
Phil H
Club RR Member Number: 133
jumpstart connectorPhil H
@philhoward
Club Retro Rides Member 133
Beware of making the leads too long - I think part of the reason they get away with small diameter cables is because of a very low volts drop over such a short distance. Your "extension" cables would need to be the same as the normal battery cables - probably 35mm or so. 16mm at a push.
MiataMark
@garra
Thanks EC5, 5 pairs for £6 on eBay.
Noted re length of cables, what I really want is to have 'tails' to the battery, using decent gauge cable, that I can plug a variety of things into, charger, solar panel, jump leads...
Might end up using 50A Anderson plugs though, but they're more like £6 each. (EC5 rated at 80-100A?)
