1968 CHAMBERS SPECIAL
THIS CAR WAS BUILT BY BILL MARK CHAMBERS AN ENGINEER IN 1967 AND REGISTEERED IN 1969
TOTAL ONE OFF USING MINI AND AUSTIN 1100 PARTS
THE SHELL IS A MONOQUE WITH ALL THE SEATS MOULDED IN
THE SEATS ALL HAVE TINY HOLES IN WERE THE HOT/COLD AIR IS BLOWN THROUGH(SO VERY EARLY HEATED SEATS)
THE REAR SEATS FACE BACKWARDS/STEERING WHEEL IS ADJUSTABLE
IT HAS VENTS ON THE SIDE AND ON THE ROOF
ALL THE PLASTIC WINDOWS ARE PRESENT ALTHOUGH THEY NEED REPLACING AS THERE MISTED
ENGINE IS A A SERIES 1275 TURNS OVER OK BUT NEEDS RECON
I HAVE A REPLACEMENT FRONT SUBFRAME AND UPPER/LOWER ARMS SHAFTS,BRAKES AND NOS FITTING KIT(SEALS ETC)
THE REAR IS BEAM AXLE THAT NEEDS REPLACING
ALL THE RUNNING GEAR IS PRESENT/DRIVE SHAFTS,BRAKES ETC ETC
don't BE MISLEAD THIS CAR NEEDS LOADS OF WORK,THE SUBFRAMES ARE BONDED TO THE BODY SO NEED CUTTING OUT AND REGLASSING
THE SHELL NEEDS REPLARES TO THE FIBREGLASS ALTHOUGH IT IS SUPER SOLID.
ALL THE PANEL WORK/GAUGES ARE PRESENT BUT AGAIN NEED WORK
V5 SAYS BMC SPECIAL
THIS IS SO UNIQUE AND IT HAS TO BE SAVED.AND I JUST don't HAVE THE TIME
LAST 5 PICTURES ARE HOW THE CAR USED TO LOOK,ENGINE IS CURRENTLY OUT OF CAR
IAM OPEN TO OFFERS PRICE ON ADD IS JUST FOR RULES
V5 SAYS BMC SPECIAL
