Feb 24, 2019 21:41:53 GMT
Hi, looking for advice on how to safely dismantle a steering wheel airbag and remove the explosive element and bag. I want to use the wheel and column and horn push for a project that does not require airbags. Obviously not having an electrical connection is a good start when handling it but how careful should do you have to be.I bet theres someone on this forum that's done it? Thanks
slater
Club RR Member Number: 78
Steering wheel airbagslater
@slater
Club Retro Rides Member 78
You should just be able to undo the 4 bolts.
Feb 25, 2019 18:26:56 GMT
You should just be able to undo the 4 bolts. Sorry that's a generic picture, mine has no visible bolts to get at as far as I can see. Two aluminium rivets at the side will I think need drilling out , but really I'm concerned with the safety aspect of "messing" with these
Rich
Club RR Member Number: 160
Steering wheel airbagRich
@foxmcintyre
Club Retro Rides Member 160
Feb 25, 2019 19:42:19 GMT
Personally, i'd just use a non-airbag wheel be it an OE wheel or an aftermarket replacement. Yes, you could separate the pyrotechnics and the bag from the 'unit' but it could be risky, one false move. Not saying you could easily trigger it, I work with airbag systems on a regular basis but I follow the safety regime pretty well and I am only usually removing and re-installing, not 'tampering', as the manufacturers would call it.
Rich
@foxmcintyre
Feb 25, 2019 19:43:41 GMT
Also if you remove the device, the wheel centre will be really soft and prone to splitting along the detonation safety seams. Obviously pretty easy to overcome as an afterthought to the main dismantling but worth considering.
Feb 26, 2019 19:18:15 GMT
Thanks for your thoughts Rich, have you ever seen or heard of one going off with no wires attached to it?
Rich
@foxmcintyre
Feb 26, 2019 20:19:02 GMT
Thanks for your thoughts Rich, have you ever seen or heard of one going off with no wires attached to it? Not an electrical one, no. Mechanically triggered, yes, but that's a different kettle of fish. But it's a risk you want to consider.
Feb 26, 2019 22:15:13 GMT
You should just be able to undo the 4 bolts. Sorry that's a generic picture, mine has no visible bolts to get at as far as I can see. Two aluminium rivets at the side will I think need drilling out , but really I'm concerned with the safety aspect of "messing" with these Put up a picture or tell us what the wheel is from and you may get a definitive on whether it can be done safely.
madmog
Club RR Member Number: 46
Steering wheel airbagmadmog
@madmog
Club Retro Rides Member 46
Feb 26, 2019 23:27:06 GMT
Personally, i'd just use a non-airbag wheel be it an OE wheel or an aftermarket replacement. Yes, you could separate the pyrotechnics and the bag from the 'unit' but it could be risky, one false move. Not saying you could easily trigger it, I work with airbag systems on a regular basis but I follow the safety regime pretty well and I am only usually removing and re-installing, not 'tampering', as the manufacturers would call it. What do you do with the old airbags, do you set them off or is there a disposal channel?
Rich
@foxmcintyre
Personally, i'd just use a non-airbag wheel be it an OE wheel or an aftermarket replacement. Yes, you could separate the pyrotechnics and the bag from the 'unit' but it could be risky, one false move. Not saying you could easily trigger it, I work with airbag systems on a regular basis but I follow the safety regime pretty well and I am only usually removing and re-installing, not 'tampering', as the manufacturers would call it. What do you do with the old airbags, do you set them off or is there a disposal channel? Usual practice is deploy safely and dispose. Normally clamped in a vice well away from yourself and detonate, we had an explosives cabinet when I worked at a large main dealer and we could store them safely and have a set-off once a month of the units we replaced. Theory I guess was it saved dragging the det-kit out every time or something but a coil of long wire and a battery do the same job.
vitessetony
Club RR Member Number: 114
Steering wheel airbagvitessetony
@vitessetony
Club Retro Rides Member 114
Probably a daft question but can't you just keep the airbag and not connect it up? That way you'll keep the integrity of the wheel centre and not fire yourself into outer space whilst drilling the rivets!
Feb 27, 2019 19:25:51 GMT
Probably a daft question but can't you just keep the airbag and not connect it up? That way you'll keep the integrity of the wheel centre and not fire yourself into outer space whilst drilling the rivets! I'd go with this option ^^^^^ if you don't plug the air bag in it won't go off so it's as safe as it would be in the car it was removed from. They've been fitting air bags to cars for over 20 years now and generally the older they get the less chance they have of working at all it needs a power supply to set it off so I recon your better of using it as it is instead of attempting to take in apart and maybe loosing some fingers
1992 240 Volvo T8 1955 Cadillac 1994 BMW E34 M5 (now sold ) 1999 BMW E36 sport touring x2 1967 Hillman imp Californian "rally spec" 1971 VW bay window (work in progress) 1999 Mazda 323F 1987 Jaguar XJ12 All current
Feb 27, 2019 20:39:41 GMT
The wheel is from a 2002 ford KA the whole assembly steering column will be retrofitted in a completely different older vehicle and the reason for wanting to disarm the airbag is I don't want it going off. If it is not connected electrically then I cant see what would set it off. I'd rather not have it there though, just in case. Hence my question is it safe to dismantle if its not connected? Just looking for a definitive answer.
vitessetony
@vitessetony
Feb 27, 2019 20:54:00 GMT
The wheel is from a 2002 ford KA the whole assembly steering column will be retrofitted in a completely different older vehicle and the reason for wanting to disarm the airbag is I don't want it going off. If it is not connected electrically then I cant see what would set it off. I'd rather not have it there though, just in case. Hence my question is it safe to dismantle if its not connected? Just looking for a definitive answer. I would say no, as after all's said and done, there are still explosives within it. Why not go with a boss kit and aftermarket wheel and avoid this whole airbag situation?
