Apr 18, 2019 16:11:52 GMT
Got some more done this afternoon, both the rear pillars and nearside c post are carpet lined.The sliding door trim is carpet lined and refitted. Both the rear quarter panel trims are made, the drivers side has been fitted and the passenger side just needs finessing and lining. Both the screens for the rear door windows are made. That's it now until Sunday. Cheers - mike
Apr 20, 2019 14:01:31 GMT
Hi all got a few hours on the camper earlier. I was supposed to be walking around Ingleton but decided to give a miss due to the weather and the bank holiday madness out and about. The passenger side rear quarter panel is now carpet lined and fully fitted and the passenger side rear door is finished. I have to tidy up the paintwork as it was pretty battle scarred. Also spent an hour realigning the sliding door as you had to give a good slam to get it to latch and often it sprung back open.It was mainly due to the top runner being miles out and the rear striker plate being loose.Anyways it now shuts as it should and sits properly. Tomorrow should see the carpet lining around the kitchen window,cab step and top rear of the roof done and hopefully the flooring down. Cheers - mike
jpsmit
Apr 21, 2019 16:59:49 GMT
Mike, that looks amazing! Does the carpet over the wheel wells come formed? Or do you do it and if so, how?
Thanks
Apr 22, 2019 18:55:37 GMT
Mike, that looks amazing! Does the carpet over the wheel wells come formed? Or do you do it and if so, how? Thanks Hi there the carpet for the wheel wells just comes flat of the roll and you have to stretch / form it yourself as you apply it. If you use 4 way stretch its not to hard if you have done a few. Cheers - mike
Apr 23, 2019 11:55:22 GMT
Hi all
got a few hours on the camper this morning,
I have fitted the split charge relay and wiring. Its now been tested and is working fine so I can refit the battery cover and flooring.
A common fault on these vans is for the heater fan to only work on full and this van was now exception so I have pulled the heater resistor and replaced it. I also had to repair the main feed wire as it was showing signs of distress.
Whilst under the bonnet I have also changed the air and fuel filter as part on the service so just the engine oil and filter to do later. I was pleasantly surprised to see both the fuel and air filter had been done pretty recently.
I hope to get the flooring down on the rear of the van later and have a tidy up as I'm going over to Cleethorpes in her tomorrow to collect some furniture board.
Cheers - mike
Apr 23, 2019 18:53:33 GMT
hi all got the flooring cut and installed the rear is now fully fitted and has had edging fitted. The area around the step needs to be cut and then finished with edging. I also finished the install of the camera system by adding a hidden 12volt outlet in the unoccupied passenger air bag space. I need to do a few jobs underneath tomorrow before going over to Cleethorpes. The wiring for the split charge supply to the leisure batter needs routing and securing and the captivated nuts for the rear door striker plates need replacing. Thursday should see the rock and roll bed bolted together and in position and the kitchen unit should be started. Cheers - mike
Apr 24, 2019 13:42:15 GMT
Hi all got some more done on the camper but nit as much as I had hoped as I spent most the morning with a customer. When I removed the rear door striker plates to carpet the step all the captivated nuts broke loose so I have had to spend an hour sorting them out.I also repainted the latches and refitted them. On the plus side the rear doors now shut much better. I have carpeted around the side window,insulated the area thats behind the upper rear quarter panel, made the kitchen rear panel and refitted the rear quarter panel trim. Thats about it for today as i have a quiche to make for tea. Cheers - mike
Apr 26, 2019 14:26:25 GMT
Hi all
not done a huge amount over the last few days as the weather has turned cold and wet and my arthritis has flared up.
All the wiring is fitted for the 12v systems,the mains lead and home adapter lead are made,the battery box is made and a few bits have been tided up.
The weather looks lousy now for a few days so nit a lot will get done.
Cheers - mike
Apr 29, 2019 17:51:01 GMT
Hi all
got a few hours on the camper today. The 240 volt electrics are now fully installed and tested.
I have been running the inverter and fridge today to check they are ok and they are.
I have also cut back and started trimming around the side door step.
I should be making up and installing the seat tomorrow, weather permitting.
Cheers - mike
Hi all
Not much to update on the camper as I'm away in Rhodes. I should have it finished within a week when I get back. The next one will be a high spec conversion on a Fiat Ducati and that may be my last one for a while as i'm due to move sometime in June and the new place needs lots of work.
Cheers Mike
May 12, 2019 13:16:15 GMT
Hi all got a few hours on the camper earlier. I have made and finished to rear ceiling. Its a different design to the last one and I wanted to keep the original rear light. Hope to get the front ceiling template made later. Cheers - mike
May 13, 2019 14:04:39 GMT
Hi all got a few hours in the vivaro today, not having a good day today though so not much done. The front ceiling panel is made and fitted along with the main light and the one for above the kitchen area. I have also re-used the original van light that was in the ceiling, its now moved to above the sliding door and as with all the others been fitted with an led bulb. Going to spend an hour cleaning her out next and than i'm ready for making the units tomorrow / weds. Cheers - mike
May 19, 2019 10:07:07 GMT
Hi all not done much on the camper this week as we had a new arrival to the family. Anyways, the fridge housing is made and fitted, the blank for the worktop has been made and a few other odds and sods. The family have all gone out to show off the new baby now so going to try and make the kitchen front panel before they return. Cheers - mike
May 19, 2019 13:44:58 GMT
Hi all sneaked another hour or so outside whilst it was quiet. The front kitchen panel is now made and the door is fitted. Tomorrow should see the seat fitted and maybe the wardrobe panels made. Back at the hospital tomorrow afternoon so will have to see how it goes. Cheers - mike
May 22, 2019 17:08:16 GMT
Hi all got a few hours on the camper today I have finalised the fit and shape of the worktop. Its quite a bit bigger than the previous versions as i'm fitting a larger sink than usual. I have made and finessed the fit of the wardrobe end panel so that just leaves the other end panel and the wardrobe front. I should get the work top laminated in the morning ready for the edging to be fitted and hopefully tomorrow afternoon should see the last panels and doors made. Cheers - mike
May 23, 2019 11:58:19 GMT
Looks great as always😎
May 23, 2019 14:02:57 GMT
Hi all got another few hours on the camper today after going to the tip and going to vote. The kitchen worktop is now finished along the the rear wardrobe panel and door. So that just leaves the wardrobe front panel and door left to do before the final fit up. Next job is to add the pocket holes to the kitchen front panel and worktop and then these can be fitted for good. Once they are in I can measure up for the wardrobe front panel and finalise the size of the door. Cheers - mike
May 24, 2019 11:35:51 GMT
Hi all had a steady morning making the last major panel. The wardrobe front and door is now made and ready to fit,the table top is made and the worktop has been finished and fitted for good. The pop up socket is in and tested. This afternoon should see the wardrobe panels fitted for good. I just have the wardrobe top panel to make. I should also get the mount for the table fitted. We are off to the coast in her on Sunday and then she will be valeted, re-mot'd and put up for sale. Cheers - mike
May 25, 2019 13:29:12 GMT
Hi all got a few more bits done this morning in between servicing the mother in laws car and getting the wifes car mot'd. The glass lid for the sink is fitted and the storage clip for the table leg. I also spent an hour machine polishing the side of my next project and applying some trial graphics.So far its had the side windows fitted and thats it. I hope to get a proper start on it next week weather permitting. Cheers - mike
May 25, 2019 15:18:12 GMT
Hi all
got a bit more done,
the table mount is now fitted to the table and the floor. Thats about it now apart from fitting the water pump and waste pipe. I won't fit the waste pipe until the van is sold as some people want a waste container in the van and others want it routed out through the floor.She will get a full valet tomorrow and maybe a polish.
Got a few minutes on the blue van. I have applied some more graphics and flatted and machine polished the front wing and head light.
Cheers - mike
