You have a rare opportunity to purchase a Mk1 Golf upgraded 80's Audi 2.2 Throttle Body. Direct upgrade for any 1.6/1.8 8v EX GTI Mk1 Golf/Scirocco/Jetta.
I've had this refurbished and with performance upgrades.
Ported and Polished Audi 2.2 Quattro Throttle body to fix an Mk1 Golf Inlet manifold. This Throttle Body will fix straight without any modification on to mk1 golf 1.6 or 1.8 GTI Inlet manifold. To optimize the performance you will have to make the inlet manifold port where the TB fits larger to help with air free flow. This throttle body will increase performance up to 10-12bhp.
This Throttle body is Highly Polished inside, I like to say its AS SMOOTH AS A BABIES BOTTOM.
The ports now measure - larger 54mm from 52mm and smaller 38mm from 34mm on the polished/ported side.
Audi 42mm throttle body – Popular upgrade on k-jet fuel injection larger throttle body fits directly on to any 8v GTI existing inlet manifold.
These don't come up for sale often.
Bidding will not end early and please bid to buy.
To add I also have on a separate auction a Mk2 16v warm up regular (WUR) which is also a direct replacement and will boost fuel plus with better air intake from this throttle body will increase performance further.
www.ebay.co.uk/itm/202558574643
For auction very RARE, a used genuine Bosch Fuel Warm Up Regular to fit 1.8 1986 onwards 16v Mk2 Golf GTI's and also Corrados with 1.8 16v KR engine. PART NUMBER IS VW part No. 027 133 403 / Bosch K-Jetronic 0 438 140 140
This has been performance tuned by Stealth Racing in Warwickshire. Rolling roaded. My Mk1 GOlf was running 162Bhp from 1.8. You can see from the underside where brass part has been drilled out to show a tuning screw.
Fully working when removed this weekend. Decided to go for a turbo route so up for sale.
Unit never been opened. s you can see from the screw paint.
www.ebay.co.uk/itm/202558570674
