Ritchie
Club RR Member Number: 12
Alfa 155 coupe 20vt engine Ritchie
@ritchie
Club Retro Rides Member 12
Great job, I have serious want for one of these and it'll be twice as good with the 5 cylinder lump.
Still not running as need a relay. Fitted new tank straps, rubber boot between tank filler to outer wing and tank breather
Sept 8, 2019 19:07:38 GMT
Well got a s/hand ecu, fitted it the fuel pump primed and started but didnβt have much time to work on it today as was trying to sort a oil leak on the wifeβs daily driver
Nov 20, 2019 19:50:29 GMT
Well I lost all my motivation with the 155 after getting it running with the replacement ecu was only on 3 cylinders because 2 injectors were blocked but as I was checking coils were sparking the water pump pulley which is pushed no come off, slightly bent 2 inlet valves and 2 exhaust valves. Buying the fiat coupe 20vt few weeks ago, getting motβd and using it has got my motivation back. So valves are sorted and had the cylinder head skimmed
Nov 21, 2019 19:24:09 GMT
Mot booked for Saturday the 30th so just over a week to get cylinder head back together, fitted and running
Nov 22, 2019 14:11:42 GMT
Iβve put the cylinder head back together. Head fitted torqued, exhaust manifold bolted on, radiator hoses fitted, inlet manifold fitted and timing belt fitted
Nov 22, 2019 15:10:28 GMT
That's a sweet car man. I do like an Alfa.
Nov 22, 2019 15:20:29 GMT
That's a sweet car man. I do like an Alfa. Thanks Iβve also got a Alfa 156 Gta 3.2 on a 2004 plus all the other ones in my signature
Nov 22, 2019 15:21:13 GMT
Nov 23, 2019 15:04:28 GMT
All back together just need 2 injectors to get it running. Need a tyre on the 16β speedline 5 spoke on Monday and battery is on charge at the moment. Today I fitted the poly engine bushes/mount, checked the injectors to find out the 2 that I thought were u/s are not working, fitted the cam cover, coils, intercooler pipes, vac pipes, coolant tank and filled the rad up with coolant
Nov 25, 2019 16:49:00 GMT
Fitted 2 injectors and the battery as it was recharged. Now running
Nov 25, 2019 17:08:23 GMT
Plus got tyre on the 16β speedline so already for mot on Saturday Collected the tsw 17β alloys from being powder coated get tyres around Xmas time Also need 330mm front discs and brackets to fit Alfa 159 brembo calipers.
Hell yeah awesome car love 155s, and even better with the 20vT. One point of clarification in case it makes a difference. FMIC stands for 'Full Metal Intercooler', and the one you have has plastic end-caps. Normally not such a pedant, but depending on the boost level you're planning to run you might need an intercooler that's got welded ally end caps (run silly boost through a half-metal intercooler and you can pop the ends off if they're not strapped down better). If it's been sold to you as a full-metal one it's not. If all you were after was a bigger one then all's well. Doesn't overly matter if it's got plastic caps.
Nov 26, 2019 14:28:12 GMT
Does FMIC not stand for Front Mount(ed) InterCooler?
Nov 26, 2019 15:10:57 GMT
Huh, I suppose it could well do! I'd always assumed it was full-metal as the Uno Turbo one on my Fiat has a habit of popping the plastic caps off the top if you put too much boost through them so everyone talks about full-metal intercoolers. As you were everyone, carry on. Nothing to see here
Last Edit: Nov 26, 2019 15:11:37 GMT by biturbo228
Nov 26, 2019 15:44:35 GMT
I always thought it was front mount intercooler...... the Evo is a full metal one itβs used by loads of Fiat Coupe owners as a cheap way to do it. My Fiat Coupe 20v turbo has a std intercooler with plastic ends on it
Nov 26, 2019 18:18:42 GMT
Great car BTW 'busso...I've had loads of 155s and love 'em to bits!
Nov 27, 2019 17:51:45 GMT
Run it up this morning for about a hour, finished putting it a few bits of dash and replaced some dash bulbs
Nov 30, 2019 12:31:41 GMT
Saturday morning mot passed clean bill of health π π last mot was April 17. I started getting the bits I was missing to do the fiat coupe 20vt engine conversion a year ago. Was nice driving it again
