Hi all
I'm after a thin wall socket to remove the mirrors from my acty - At some point 10mm head screws have been used (instead of standard screws that a screwdriver could remove) in a recess about 12mm so a normal socket won't fit in.
Typically I threw away an ikea hexagon tube socket before christmas but that's the kind of thing I need - just a fraction thicker than the metal bolt head itself.
It shouldn't be in that tight so a manual one would do i think.
Google is bringing a limited amount amongst normal sockets but online don't specify the diameter of the outer metal of the socket.
Thank in advance.
Thank in advance.
