Roach
Dec 26, 2018 10:28:15 GMT
Got one of these that’s surplus to requirements. It’s unused and in its original packaging. These things kick out a serious amount of heat and will keep you toastie in the shed on these winter nights. I can courier it to your door all in for 75 quid. That’s a snip of the price they retail at.
Last Edit: Dec 30, 2018 14:50:16 GMT by Roach
Dec 29, 2018 19:50:46 GMT
hmmm......quite interested, need to do a bit of research to see if it's what I need first.
Dec 29, 2018 19:57:41 GMT
Can I have first refusal based on a few answers please?
How far away from any/everything does it need to be to avoid burning anything?
Roach
Dec 29, 2018 20:09:16 GMT
Here you go. I just took photos of the instructions. Think it’s suggesting 1m... you don't want your head too close to it that’s for sure.
Dec 29, 2018 20:10:53 GMT
Ok gotta go out now but will read later and let you know.
Dec 29, 2018 23:00:57 GMT
Ok, I think I can make that work - might be a bit hot if I walk under it though!! I can do Paypal if you want to PM me details.
Roach
Dec 30, 2018 12:13:32 GMT
Pm sent bud.
Dec 30, 2018 12:43:05 GMT
Mark - I have a very similar 3Kw heater - similar head unit to the one that's for sale here - mine is on a professional bodyshop stand They are readily available in the market but are circa £350 / £400 - If you knock a stand up for it - it will be far more usable - that way you can just put it where you are working by setting the height / angle of the head - you can also get digital timers for them - it's an invaluable piece of kit in my workshop - then again I also run a oil filled electric rad on a timer just has background to keep the chill out of the workshop
Last Edit: Dec 30, 2018 12:44:29 GMT by Deleted
Dec 30, 2018 13:43:10 GMT
Ross,payment now sent.
Chris, do you have a link to the digital timers please? i can knock up a stand for it easily enough.
Roach
Dec 30, 2018 14:23:53 GMT
Sold, cheers bud.
Dec 30, 2018 15:49:15 GMT
Ross,payment now sent. Chris, do you have a link to the digital timers please? i can knock up a stand for it easily enough. www.spraygunsdirect.co.uk/index.php/timer-unit-only-iukhir103.html#sthash.ZRosmZI7.dpbsMark - The Iwata timers might be a little on the expensive side at just over £100 - they only time the duration that they are switched on for and will set up to 99 mins - pretty sure that a ready made 3Kw digital timer from elsewhere can be adapted quite easily to do the job
Dec 30, 2018 16:27:14 GMT
Thanks Chris, yes a bit expensive! I'm sure I can do something for a lot less. Edit, This should work fine I think? Timeguard TGBT4They do a 13A socket version as well. Timeguard TGBT6
Dec 30, 2018 19:53:17 GMT
Thanks Chris, yes a bit expensive! I'm sure I can do something for a lot less. Edit, This should work fine I think? Timeguard TGBT4They do a 13A socket version as well. Timeguard TGBT6Either of those will be fine - it just gives you the flexibility to use the heater on a panel for a set amount of time - I quite often set the timer and walk away and let it get on with the job whilst I do something else - I do use a hand held temperature sensor to ensure that the panel / paint is not heated to excess - sub 60c is fine (but it's worth checking the data sheet on the paint to make sure)
Dec 30, 2018 19:58:26 GMT
Thanks Chris.
SOLDjohnthesparky
@johnthesparky
Club Retro Rides Member 6
Thanks Chris, yes a bit expensive! I'm sure I can do something for a lot less. Edit, This should work fine I think? Timeguard TGBT4They do a 13A socket version as well. Timeguard TGBT6Either of those will be fine - it just gives you the flexibility to use the heater on a panel for a set amount of time - I quite often set the timer and walk away and let it get on with the job whilst I do something else - I do use a hand held temperature sensor to ensure that the panel / paint is not heated to excess - sub 60c is fine (but it's worth checking the data sheet on the paint to make sure) If you are using a socket one, just be aware that a 13a 3 pin plug has a duty cycle and won’t like running for hours and hours at 3kw (12A) if that happens you may find it gets too hot around the pins (they go brown, you get cracking etc at first)
I'm going to get the immersion heater boost one - so no 13a plug.
