moglite
Club RR Member Number: 144
Dec 16, 2018 18:01:44 GMT
I want to rework the spring pans on my Morris Oxford, to take the new air-springs. I need to cut out the existing bump stop mount. If I create a "pocket" I can get the car much lower. To do this I need a couple of lengths of tube - max 75mm long. The tube needs to be 125-130mm OD and something handy to 3mm wall thickness Anyone have such a piece of steel hidden in their scrap pile, or know where I can get some. Thanks
Last Edit: Dec 16, 2018 21:29:39 GMT by moglite
ChrisT
Club RR Member Number: 225
Dec 16, 2018 18:15:38 GMT
Usually would have something in the workshop, unfortunately we did a pre xmas scrap run last week, will look tomorrow... Whereabouts are you?
moglite
Dec 16, 2018 19:15:00 GMT
Usually would have something in the workshop, unfortunately we did a pre xmas scrap run last week, will look tomorrow... Whereabouts are you? Thanks - I live in Hampshire, sometime work in Slough
ChrisT
Dec 16, 2018 19:24:55 GMT
A bit too far from Lincoln then....
Suggest you look up local roller shutter door makers, 5" tube is one of the standard sizes used for making the barrel, they'll probably have offcuts....
Dez
Club RR Member Number: 34
Dec 16, 2018 20:31:35 GMT
Cheap enough on eBay to the spec you want. I only ever buy 1/2 metre or metre lengths for doing the same thing.
moglite
Dec 16, 2018 20:57:16 GMT
Cheap enough on eBay to the spec you want. I only ever buy 1/2 metre or metre lengths for doing the same thing. I had looked on eBay, but the clue was in the previous post - 5" tube. I looked for 125mm and 130mm, but I never thought of 127mm Sorted now - thanks all.
