mungo
Dec 13, 2018 10:36:06 GMT
Garage crew Do you think the plastic "garage floor" tiles would be good enough insulation to stop the dreaded wet concrete floor? This kind of thing: big dug flooring I'll want to be jacking cars and maybe have a car of dollies ...normal kind of deal ... Any got these type of tiles down in their garage ? cheers
56' bug 2332 +ida's 56' lowlight ghia 72' bus 1600 devon 67' type 3 square - gone 83' gti - gone 90' gti 16v - gone 82' chevette - gone 70' GP1 Beach buggy -gone 78' lightweight landrover 3L v6 -gone 89' gti - gone 83' gti - gone
Dec 14, 2018 19:44:11 GMT
If you look past the car parts you can see the plastic tile flooring I have Quite expensive but I think it was worth it easy to keep clean and if you drop your tools on the floor it don't scratch it Only down side is plastic don't like heat so if you cut a bolt head off and it's red hot it will melt into the tile The other thing is if you park your car after a brisk drive the heat from the exhaust can warp the tiles
1992 240 Volvo T8 1955 Cadillac 1994 BMW E34 M5 (now sold ) 1999 BMW E36 sport touring x2 1967 Hillman imp Californian "rally spec" 1971 VW bay window (work in progress) 1999 Mazda 323F 1987 Jaguar XJ12 All current
mungo
I case any searches this in the future!! Thanks to nalesutol 's recommendation I got a few packs of the foam floor tiles from B&Q. These badgers: hereand if you're feeling even more bourgeois you can get colored ones! here They're lovely under foot , not great for rolling stuff on though , loads cheaper than the hard one's from bigdug . perfect for low traffic home garage. I'll get another load at some point .
I case any searches this in the future!! Thanks to nalesutol 's recommendation I got a few packs of the foam floor tiles from B&Q. These badgers: hereand if you're feeling even more bourgeois you can get colored ones! here They're lovely under foot , not great for rolling stuff on though , loads cheaper than the hard one's from bigdug . perfect for low traffic home garage. I'll get another load at some point . How do they take a trolley jack with load? Does it dig in and ruin them?
mungo
Oh yeah. the wheels will dig in with nowt on the jack! It needs boards under the jack and axle stands. You could pull out the tiles where you need to take weight..... I just put boards down. These are cheap foam tiles not the expensive hard plastic ones. pays your money.... Takes your chance. I like them.
Jul 18, 2019 15:17:43 GMT
Where does the condensation come from? Is it ground damp from the concrete not having DPM under it?
