pxr5
I picked up a burnt out Mev Rocket ( engine mounted out at the back ), no history or doc's, I thought the engine was a Zetec but its not, looking at the rear of the car, the twin cam belt is at the right, the exhausts are rear most, the engine is on carbs maybe R1's?, they are on the side between the engine and the seats. Ive googled it, I thought maybe a Duratec but Ive not found any pics that look the same....It looks like a Zetec with a Duratec head? I'm confused...Any ideas? thanks
Last Edit: Dec 8, 2018 22:17:19 GMT by pxr5
What Ford engine is this ?stealthstylz
@stealthstylz
Club Retro Rides Member 174
Only Ford engine I can think of that is that way round with a cambelt is a Puma engine. Duratec is that way round but has a timing chain.
pxr5
Hopefully you can see this engine, its the same, its on ebay listed as a FORD FIESTA ZETEC MK6.5 2008 COMPLETE DURATEC ENGINE , What exactly is it? thanks...
Last Edit: Dec 9, 2018 17:39:28 GMT by pxr5
What Ford engine is this ?ChasR
@chasr
Club Retro Rides Member 170
Do you have more shots?
I'm going with a Sigma/Zetec-SE engine as well from a Puma/Fiesta/Focus.
Do you have more shots? I'm going with a Sigma/Zetec-SE engine as well from a Puma/Fiesta/Focus. I'd be agreeing with you ports don't look true 'zetec' or duratec.
pxr5
pxr5
I need another engine,are the mounts the same for Zetec, / Duratec engine & boxs? whats the biggest capacity they do in this engine family? thanks
That is a bog standard duratec, nothing special.
I need another engine,are the mounts the same for Zetec, / Duratec engine & boxs? whats the biggest capacity they do in this engine family? thanks You most likely have a 1.6 duratec, the bigger 1.8/2.0 engines use a timing chain. I'm not 100% sure if the mounts are the same, but you car is based on a focus so anything that comes in one of those should be adaptable.
pxr5
Ah yes, it was the cam belt not chains that was confusing me, thanks for the info!
mk2cossie
Club RR Member Number: 77
What Ford engine is this ?mk2cossie
@mk2cossie
Club Retro Rides Member 77
If your engine matches the pics, that is a Sigma or Zetec SE engine. Labelled by Ford as Duratec on the airbox mounted on top just to confuse
Dec 10, 2018 18:49:50 GMT
And the largest capacity is the 1.7 fitted to the puma.
pxr5
Dec 10, 2018 20:47:18 GMT
Thats very helpfull thanks
Dec 11, 2018 19:21:07 GMT
mevs typically used 2.0 zetec engines from mondeos and the like, I helped a friend of a friend fit an ST170 engine and box into one, it was actually labeled Duratec on the cam covers.
pxr5
Dec 11, 2018 23:18:26 GMT
Yes, the engines thats in it is not as powerfull as I would like, a 2L + engine would be the way to go, thanks
@stealthstylz
Dec 11, 2018 23:50:59 GMT
They're very light. The Zetec/ST170 is iron block and very heavy in comparison.
Dec 13, 2018 18:43:39 GMT
indeed, the sigma can make very decent power and bloody good noises, they are nice and light and the design of the block lends to good stiffness and lower vibrations.
the steel 2.0 is a heavy old curse word, though ultimately being larger capacity some simple mild cams itb's and a decent manifold will get you near 200 bhp.
or fit a stock Honda K20..
@chasr
Dec 14, 2018 19:35:01 GMT
What they said above. They are very light and it doesn't take alot to get good relative power out of them.
tristanh
Routinely bewildered
Dec 14, 2018 19:45:10 GMT
What they said above. They are very light and it doesn't take alot to get good relative power out of them. I've 150 bhp in my 1.4 one. Mild porting, rally cams, and gsxr throttle bodies. Very underrated engine. All alloy, a Yamaha design with front facing induction. Main reason I think more aren't used in other stuff is that the Bell housing pattern is different to the RWD ford pattern. Mate of mine rallied his 1.4 with 190 bhp in it.
pxr5
Dec 15, 2018 21:34:19 GMT
Any one know the cam specs on a stock 1.7 SE ? thanks I now have the info......
Last Edit: Dec 16, 2018 0:32:01 GMT by pxr5
