Got some remade Sierra parts. These are not genuine Ford parts but replacement copies or redesigned parts.
These were started after i was after some RS Sapphire side skirt clips and found they were no longer available at a reasonable cost.
Parts available are:
Sapphire RS Cosworth side skirt clips rivet on: Full kit of 16 clips the same as the ford clips and are rivet on. £55 delivered to UK postcodes
Sapphire RS Cosworth side skirt clips screw on reinforced: Full kit of 16 clips redesigned as a stronger direct replacement for the ford clips and are screw on. £55 delivered to UK postcodes.
Sapphire RS Cosworth side skirt wing mounting brackets: Kit of 2 Brackets (Top in photo) the same as the ford brackets(Bottom in photo). £20 delivered to UK postcodes.
Sapphire RS Cosworth side skirt clips and brackets: Full kit of 16 clips either screw on or rivet on and the wing brackets. £71 delivered to UK postcodes.
Sapphire RS Cosworth front bumper towing eye cover: Similar to the Ford part but extended to meet the bumper recess better. These are unpainted in either black or white. £35 delivered to UK postcodes.
Sierra mk2 door pocket screw caps: flat surface, not texture £4 £20 delivered to UK postcodes.
Sierra RS cosworth 2wd power steering pipe mounting bushes: Direct replacement for the Ford part (original on left in photo). £15 delivered to UK postcodes.
Sierra mk1 boot jacking cover screw: Direct replacement for the ford part, but not textured surface. £8 delivered to UK postcodes.
