cactus
Nov 28, 2018 13:52:16 GMT
I'm breaking an Eagle RV and have had calls for the engine. It's a re-con and has run for less than 20mins. It's NOT the 205 Block which h seems to stop the conversations dead! Are they of no value the early ones??? Any ideas please?
Nov 29, 2018 19:30:35 GMT
205 blocked ones are more sought after. There is nothing wrong with your block that said. bit like the old 711m xflow palava..(691m is still good!) anyway..
I would say as a complete known running engine ,with most bits like carb zorst dizzt alt etc, look for around £300 ish mark.
scimjim
Club RR Member Number: 8
2.0 Pinto lumpscimjim
@scimjim
Club Retro Rides Member 8
Nov 30, 2018 11:24:57 GMT
A 2.0 litre with new dizzy and 205 block went for £250 earlier in the year on locostbuilders.
tezybonk1
Toolmakers do it with precision
Jan 15, 2019 18:52:23 GMT
Hi Sorry to butt into your post but am I correct in thinking you can put the Cosworth 16v head on top of the Pinto engine, or is that incorrect?
voodoo57
That's not 2 metres! come a little...Closer!
Club RR Member Number: 137
2.0 Pinto lumpvoodoo57
@voodoo57
Club Retro Rides Member 137
just a few mods required, possibly a few more? aux drive pulley cambelt drive pulley (crank end) exhaust manifold dizzy cap camshafts
Best to ring a qualified engine builder, maybe track and road in rainham can help? or try SBD motorsport etc.... someone will know. Good luck!
What's the number on the block and head
