IMG_20171202_130205 by Graham Miller, on Flickr
So... I've got the Multipla on the left, which is right at the edge of Retro Rides, being a Y plate. (Photo was taken when swapping the alloys off the modern one before selling it!) I'm finding that I need to update my knowledge - while I'm happy shimming up heads and checking points gaps, this car has a computer. Worse than that - an Italian computer!
It went through a phase of not-starting that a mobile mechanic diagnosed as the crankshaft speed sensor. This was duly replaced and it now actually starts and drives. However, it's always thrown up P0130 codes - O2 sensor circuit problems and it's always had a tendency to stall. mostly at low speed. It's had a new exhaust manifold and lambda sensor as the old lambda sensor came out with the thread.
What other sensors and witchcraft could be causing the low idle speed (around 800, can dip to 700) and frequent stalling? If it was a proper car, I'd just turn the idle speed screw up a bit and check the mixture! Oh, that reminds me, it has been serviced, coil pack, leads, plugs (which had good colour) etc.
Where else should I be looking as it's a daily driver and I want to fix it before it dies on me!
Thanks!
Graham
Thanks!
Graham
