jmsheahan
Club RR Member Number: 121
Thanks for the kind comments and offer of parts guys Please excuse the terrible photos (rubbish light in the garage) but got some paint down last night. The 'grey' bits are just leftover residue from the curse word masking tape I used, not primer. A long way from show winning but happy with that! It's all covered by the carpets and underlining anyway! Started to trial fit the trims - couple of new holes will need to be drilled due to the new arch half being welded in but that's easy to sort. I'm tempted to waxoil the outer arch with the clear UC wax before the trims go on... what do you think? Good or bad idea?
Last Edit: Mar 24, 2020 8:56:26 GMT by jmsheahan
jmsheahan
So, in a bid to keep normality in this crazy world we live in currently, some more hours smashed out this week. Rear arch trims are back on, stainless rivnuts and fixings all around so they can be removed with ease should be needed: On to the interior!I've had this rear strut base kicking around for ages to run with the 'Clubsport' theme the interior is taking on. It had been powder-coated in a horrid mottled grey/black finish so that got resprayed in satin black. Fits nicely under the parcel shelf, looks OEM and is inoffensive. The rear boot trim on a Mk2 Golf is made of a 50:50 mix. 50% milk carton, 50% unobtainium. Because of this, scene tax is slapped on and there's no way I'm forking out. Mine is in 3 pieces so I 'plastic-welded' it back together with by melting a zip tie on a soldering iron. A finishing coat of textured paint makes it perfectly serviceable. Moving forwards from the boot area... oh dear. What a state! 2 years of dust, debris, body shop grime etc mean things are not looking pretty Out with the seats: Out with the carpets: I don't have a wet vac so liberal clean with upholstery cleaner and pressure washer did a reasonable job: What does the 30-year-old sound deadening look like? It's been about 10 years since I last had this lot out. Ah... Stripped: As well as being thickly undersealed underneath, Mk2's also have a tar-based coating inside the floor pans too. A lot of this original coating was lifting in the rear footwell so only one thing for it: A heat gun, scraper and copious amounts of Xylene proved useful here! I tried to preserve as much of the original zinc coating as possible. The rest of the floorpan coating looks in really good condition so made the decision to leave that alone. Zinc primed and ready for epoxy: Any recommendations for underlay and soundproofing? Heritage do a Newton Commercial kit but it's £120! Currently looking at Silent Coat plus some more closed cell foam topping as an alternative.
Last Edit: Mar 30, 2020 9:49:37 GMT by jmsheahan
Mar 30, 2020 10:32:22 GMT
You're spot on with the silent coat and then the closed cell foam. That's the method regardless of which products you use.
I did the doors and boot on my mk2 Jetta and it made a decent difference to the road noise.
You can also get some products that can be used on the underneath of the bonnet.
Two places I didn't do were the roof and behind the dash.
jmsheahan
Mar 30, 2020 12:53:02 GMT
You're spot on with the silent coat and then the closed cell foam. That's the method regardless of which products you use. I did the doors and boot on my mk2 Jetta and it made a decent difference to the road noise. You can also get some products that can be used on the underneath of the bonnet. Two places I didn't do were the roof and behind the dash. Good to know, thanks!
jmsheahan
Last Edit: Apr 6, 2020 13:55:15 GMT by jmsheahan
Love this. Thanks for sharing, enjoying watching it come back together.
^ What he said. This is a special car and you're giving it extraordinary care. John
I've read the whole thread over the last few nights. What an great tale you've told. Thank you for sharing. Keep doing what you're doing. It looks great.
jmsheahan
Thanks guys, appreciate the kind words Having a bit of a mare with the floor pan paint at the moment. The topcoat of red reacted so it's currently looking like this again... Took the epoxy, zinc primer and the original e-coat with it. Can I get a rewiiind More soon.
jmsheahan
Last Edit: Apr 14, 2020 9:50:34 GMT by jmsheahan
Apr 14, 2020 11:51:14 GMT
Those clubsports look excellent with the raylle fabric.
Apr 14, 2020 14:37:25 GMT
interested to know ehere you got the guage pod from, been looking for one to fit my electric window area for a while
jmsheahan
Apr 14, 2020 14:48:06 GMT
Those clubsports look excellent with the raylle fabric. Thanks! I'm still not 100% sure if it's all going the right way with my 'Clubsport' theme but I'm liking how it's shaping up so far. Looks a bit weird without a rear seat but kind of pointless anyway as no-one can sit in them. I want it to look as though VW made a clubsport back in the 80's as opposed to the MK7 version. One things for sure these will be a lot more supportive than the Rallye seats and as always with anything I change, it's easily reversible interested to know ehere you got the guage pod from, been looking for one to fit my electric window area for a while It was just a universal one from ebay, DIN sized so it took a bit of fettling to fit into the console. I liked this version though as it angles the gauges slightly towards the driver. Subtle but more easily readable.
Last Edit: Apr 14, 2020 14:49:29 GMT by jmsheahan
Apr 14, 2020 15:09:57 GMT
No, clubsport is a good look on your car. I have done very similar to my tornado red mk5.
You could fit a false floor just to tidy the rear up.
Apr 14, 2020 16:03:28 GMT
Love this, great work!
Apr 14, 2020 16:41:36 GMT
I'm going through an '87 924S and pulled the dash over the weekend in order to replace the block > heater > block hoses. While I'm in there: new heater core and the same sort of foam flap seal restoration you've just done. Talk about little jobs turning big. The 924S is really just a VAG parts-special. Best, John
jmsheahan
Apr 23, 2020 11:41:25 GMT
Last Edit: Apr 24, 2020 8:09:02 GMT by jmsheahan
Apr 23, 2020 13:49:40 GMT
More exciting than seatbelts would be to fit a schroth asm harness. It clips into the rear female seatbelt things so no harness bar needed.
I have one for my mk5, only drivers side though.
teaboy
Make tea, not war.
Apr 23, 2020 13:59:52 GMT
More exciting than seatbelts would be to fit a schroth asm harness. It clips into the rear female seatbelt things so no harness bar needed. I have one for my mk5, only drivers side though. Harnesses in a road car soon become a pain. You absolutely need a harness bar, the rear straps should never go downwards ever. In a big enough accident the belts can break the seat as it tries to go downwards. There is also the subsequent crushed spine of the occupant to consider. I cringe at the thought every time I see badly fitted belts.
tristanh
Routinely bewildered
Apr 23, 2020 14:46:36 GMT
I'm so jealous of this. . I pulled the plastic arches off my Tornado... Without having to remove any screws or rivets.... I love the Clubsport idea. I've been thinking about doing the same, possibly with a cage, no rear seats, and as little sound deadening as possible.
I love your seats, I can't understand the nonsense Hype around mk2 Recaros, sure they fit straight in, and are comfortable, but at a grand or so (most of which is scene tax? I'd much prefer a modern, stronger, safer seat like yours.
Great work!
