1991 (H) BMW 735i SE Auto, glacier blue with blue velour interior. 106000 Miles, MOT due April 2019.
Specification includes electric sunroof/front seats/windows, cruise control, air conditioning and servotronic steering. All electrics work fine however the aircon is untested.
Mechanically, the engine is very strong and the automatic gearbox smooth in operation. I have recently changed the radiator and viscous coupling on a preventative basis, the water pump has also been changed during my ownership. The air intake boot was replaced this week as the original had split.
I fitted genuine BMW centre and tail exhaust sections earlier this year, complete with correct fixings and centre/tail welded together as per original. Front section is in good condition so was retained
The front suspension has had new lower track control arms and steering links fitted, all Lemforder parts. The rear suspension was completely rebuilt earlier this year using Genuine BMW shock absorbers, top mounts, springs, subframe bushes and stabiliser links.
A set of four E38 16" BBS alloys c/w new centre caps and four new matching Continental TS380 tyres were fitted a couple of years ago. Spare is a standard 15" BBS and tyre.
I have renewed most of the braking components at some point too including discs/pads/hoses however the condition of all discs was an advisory on the last MOT purely due to the car not being used very much. the front discs have developed a slight "kick" therefore a pair of new discs are included with the car but are not fitted yet.
One of the rear jacking points was getting a bit crispy therefore I had all four jacking points repaired correctly earlier this year as they all had corrosion to some degree. The bodywork is generally good however there are several minor rust spots and marks/dents/scratches on the panels. The photos do flatter the car somewhat! I can send any additional photos on request no problem
This is a really decent car that I would not hesitate to drive anywhere
Looking for a straight sale ideally however would consider a part exchange deal including a classic mini, Capri, older Vespa, Manta, E30 Touring, Z3 or Z4. I can add a little cash to the 735i price above if required.
