Oct 20, 2018 18:50:37 GMT
I have a fiat ducato 2.5 turbo diesel left hand drive. Engine code 8140.27. Engine is dead so need a replacement. What other engine will more or less drop in as finding an 8140.27 is hard work. Would an iveco or renault 8140.27 Just drop straight in?
Thanks in advance
Oct 20, 2018 23:24:18 GMT
It's the same engine.
Oct 21, 2018 10:41:46 GMT
yeah, they're Sofim engines, you may well need to swap sumps oil fillers and manifolds but with the same engine code I'd imagine it'll bolt in with a little tinkering.
Dez
Club RR Member Number: 34
Oct 21, 2018 17:59:16 GMT
The only thing you have to watch for is most rwd configuration blocks don’t have the bosses drilled for the driveshaft bearing carrier that fwd setups use. Other than that pretty much everything interchanges between blocks, but ancillaries vary quite a lot by application so you’ll need to keep your ones and swap them over.
tristanh
Routinely bewildered
Oct 21, 2018 22:59:07 GMT
The 2.8 is almost identical too.
