Oct 19, 2018 17:24:45 GMT
Hi guys - looking for recommendations! I need a temporary/last-as-long-as-possible repair on my exhaust. I've used the likes of Holt Gun Gum before and it just blows off the first time you exercise the rev needle. I need to seal blowing manifold-to-cat flanges so there's an awful lot of heat and pressure.
Wire brush the rust and fill with chemical metal perhaps?
mk2cossie
Club RR Member Number: 77
Exhaust gummk2cossie
@mk2cossie
Club Retro Rides Member 77
Oct 19, 2018 19:10:30 GMT
Try and get them as clean and flat as possible and use a new gasket woukd be my suggestion Generally if it is before the catalytic convertor or a lambda sensor you don't/shouldn't use any for of sealant that gives off vapours that can harm either. Having said that, I would use some VHT silicone sealant and leave it to cure fully before starting and see what that's like
Oct 19, 2018 19:32:04 GMT
It's not the gasket - it's the actual flanges. They're known curse word spots on the Lexus LS400 and need replacing/welding up - neither of which I can do at the moment!
Oct 19, 2018 19:57:22 GMT
if they do sell a gasket that goes in that place then use a thin slither of gun gum either side of the gasket and get it all bolted down well [and quickly], give it ten mins then just let the car idle for a while.
I have used that method on various cars over the years with no probs
in fact I have had more good results at the hot end of the exhaust using gun gum, than I have in the middle or back boxes joints.
Oct 21, 2018 17:43:06 GMT
High temp Sikaflex.
