Nissan Sunny 1.3 Monte Carlo
Only 83,000 miles
Clean Car
Starts and Runs Perfectly
Needs new brake and fuel lines where one of the brackets has corroded and also corroded the lines within the bracket.
Could also do with the suspension arms being cleaned up but other than that I can't see much wrong with the car.
The boot floor and inner wings seems to be solid.
I bought the car from a friend and had intended on doing a bit of restoration but I simply haven't got the time. Would make a great project car.
I can send photos if needed, not sure how to add them to this advert ?
Thank you.
Only 83,000 miles
Clean Car
Thank you.
