Had this a little over a year, has been used daily by either my wife transporting the kids locally or by myself for commuting.
119k miles & 11months mot
Mechanically sound having had the following replaced:
Water pump (metal impeller)
Thermostat
Radiator
Cambelt was done May 2016 it is still ok so wasn’t replaced.
2 advisories on the last Mot being age related marks to the front flexi brake pipes.
It has some marks to the paint, the worst being where a wheelie bin blew into the passenger door causing a small dint.
Rear arches are just starting to show signs of bubbling.
Sunroof although it doesn’t leak is a bit thin in places, I’ve treated these areas with por15, however I have an exceptional spare panel with brand new BMW seals I could supply.
The interior let’s the car down a little, standard wear to the drivers seat and a couple of cracks in the dash.
The car doesn’t suffer the e30 water leaks as I’ve fixed them, I replaced the boot and light cluster seals, again genuine BMW parts used.
I also replaced the M3 style aerial as it was bent.
Electric mirrors and windows all work too, I replaced a switch and cleaned the contacts.
Will do a walk around video later today/tomorrow.
Cheers Nick
07779570260
Thermostat
Radiator
Cheers Nick
07779570260
