bl1300
that's proper "alfresco" restoration , good job we aren't suffering the usual uk summer weather! It would stay under the cover until the workshop was free if we were. Whilst the weather is good I prefer working outside as I can see what I am doing a lot easier but I do have a good sized workshop that would fit 4 cars if it were not for the inspection pit slap bang in the middle. Sorting the workshop is the other major project we have been doing this week so that I can get the body inside to work on.
Current fleet.
bl1300
Aug 21, 2018 19:21:04 GMT
I'm back from holiday so back to working on the beetle today. First job was more cleaning up which uncovered, this previous bodge. This has made me need to buy a repair section as I really don't have a good point of reference to make the shape. I then set about cleaning up this little area which at first glance didn't look too bad. As always the rot extends much further than you would think and all had to be cut out revealing some missing metalwork underneath. The missing bit of the hidden panel is let in first. The whole lot is sprayed with a coat of weld through primer before a new patch is tacked in place. Fully welded in place. After attacking with a flap disc it looks like this. Sprayed in etch primer still a little fettling required.
Current fleet.
Aug 22, 2018 12:17:27 GMT
I think you might get used to being surprised by finding more rust on it. Thats a monu-mental undertaking and fair play to you for it!
luckyseven
Club RR Member Number: 45
1974 VW Beetle 1303luckyseven
@luckyseven
Club Retro Rides Member 45
Aug 22, 2018 14:07:27 GMT
Glorious madness
bl1300
Aug 25, 2018 18:35:20 GMT
This car is slowly coming together. Rear clip is welded in place Right side is now ready for the wing bolt repair panel. That is why I haven't radiused the joint to the C pillar as the repair panel will give me the radius and I would rather not cut it wrong. Second job today was cutting out the rot in the boot floor and welding in the first repair patch. This is one of the worst bits to do on the whole car but I baulked at the cost of the repair panel especially as I would only have needed a third of it and you can't buy just the bit I actually need. It is going to take some work but I think I can make this panel good again. Not sure how much more I will get done this weekend as gauge on my gas regulator is telling me my gas bottle is nearly out.
Last Edit: Aug 25, 2018 18:36:54 GMT by bl1300
Current fleet.
I owned this cars brother. I sold it last April (wish I had kept it!)
bl1300
Aug 30, 2018 20:06:35 GMT
I have been a little quiet on this thread as of late but that is because I have been busy working on ugly. Monday saw a big parts order go in to VW heritage so hopefully I should have a nice big parcel arrive tomorrow. Also on Monday we managed to free up and strip down the front brakes and struts. Sadly the struts themselves went straight onto the every growing scrap pile as both of the lower spring seats were floating loose down by the drums allowing the springs to flop around loose. One was also cracked around the base and leaking. All in all I think they were beyond repair which is a little sad as, unlike the inserts, complete struts seem a little hard to come by and are very expensive new. Then I jury rigged this little experiment together to clean up parts without the harsh nature of sandblasting. If my experiment works well I will make up a bigger, less jury rigged, tank that can be used for cleaning larger parts such as suspension arms and wheels. The next job on the list was working on repairing bubbling on the bottom of the N/S door. Cutting away the porous skin revealed that the lower part of the frame that the skin spot welds to was also compromised so out came the angle grinder again to cut away the rot. A repair section was then measured and cut out of a fresh sheet of steel before being bent using a hammer and a vice, oh what I wouldn't give for a sheet bender about now. Newly made section is then clamped in place before being butt welded into place, then a length of square section steel was clamped to the door frame and the edge dressed over with a hammer to give a mating surface for plug welding the door skin to. Lastly the a L section was added to the end to complete the full length of the door. In hindsight it would have been easier to cut further and make the first section longer than use to sections but hey ho you never stop learning. I then fabricated a new door skin repair section and welded it in place followed by copious swearing when I realised that I hadn't noticed the whole panel is slightly curved! This resulted in several hours with the panel beating hammers and dollies, and my arm feeling like it was going to fall off, to get the profile close enough that it will now only need a light skim of filler. Test fitted the door and I can't say I am that happy with the end result so more work is required. There is also one more repair need to the skin just above the lower hinge. On other notes I have also been working on cleaning up the n/s front quarter and on that front it was not nearly as bad as it looked. There was a lot of surface rust but it has brushed back to solid metal in most places. This has been treated with a rust converter and any that was too thin has been cut out and replaced. The panel isn't finished yet but is looking a lot better than it did. Hopefully will have more to post tomorrow.
Current fleet.
You really are steaming along with this! Have a look at some of the German Look forums to see about struts - I've got a vague recollection about early Golf bits being interchangeable, and also something triggered thoughts of coil-over conversions, which although using a smaller diameter spring also does away with the standard spring seat so may save your struts? I never paid too much attention to the details of 1302 and 1303 models as I've always owned torsion bar cars.
bl1300
Aug 31, 2018 19:10:49 GMT
N/S front quarter is looking much better.
Current fleet.
Samage
Sept 1, 2018 15:25:18 GMT
You're mad. Keep it up!
bl1300
Sept 1, 2018 20:18:30 GMT
A nice big parcel arrived today so I should now have most of the bit I need to tackle the really nasty bits on this car. We have a; - complete front apron panel. - O/S mud guard mount repair panel. - N/S mud guard mount repair panel. - N/S lower front quarter repair panel - Complete O/S front quarter panel. I wonder how much of that I can get in place tomorrow?
Current fleet.
bl1300
Sept 2, 2018 13:50:56 GMT
The wrecked O/S front quarter has now been consigned to the scrap pile and revealed mixed news underneath. The heater channel is good and solid as is the A pillar. The majority of the mating faces are sound. It did reveal just how bad some of the other panels are but with the quarter off it will be much easier to repair due to the much improved access. Now it is nowhere near ready for the new quarter to be fitted properly but I couldn't resist offering it up to see what it will look like.
Current fleet.
bl1300
Sept 2, 2018 18:05:48 GMT
We are currently rebuilding behind the front quarter and under the petrol tank. It's coming together even with the minor disaster caused by the earth clamp spring on the welder failing. Oh it welded so much easier after I noticed and stuck a pair of mole grips on the earth clamp to get a better circuit.
Current fleet.
1974 VW Beetle 1303Mercdan68
@forddan68
Club Retro Rides Member 68
Sept 2, 2018 18:13:56 GMT
I’m not a beetle fan, never have been But that is a real good resto your doing I’m following this with interest
Fraud owners club member 2003 W211 Mercedes E class 1998 ex bt fiesta van
Sept 2, 2018 18:42:29 GMT
I had a similar failure a year or so ago Paul, used the end of an old jump-lead as my replacement clamp. Works a treat!
Sept 2, 2018 18:54:38 GMT
doing well looking good brave men
Last Edit: Sept 2, 2018 18:55:07 GMT by shielsy68
bl1300
Sept 2, 2018 19:26:08 GMT
End of a days work, I can't do anymore today as it is now dark. I think I needed to stop as the quality of my welds suddenly dropped it's got good penetration but it is going to take some cleaning up.
Last Edit: Sept 3, 2018 7:30:59 GMT by bl1300
Current fleet.
bl1300
Sept 3, 2018 18:08:25 GMT
So far today. Some fairly extensive surgery now nearing completion. All that work and I realise I got the radius wrong and now I fear i've got to cut most of it out and start again! Now I want to cry! Oh well at least the repairs to the side of the spare wheel well have come out well. The last missing piece will be done with the wing in situe to ensure the shape is right!
Last Edit: Sept 3, 2018 18:09:02 GMT by bl1300
Current fleet.
bl1300
Sept 5, 2018 17:31:29 GMT
A little more work today starting to piece together the front crossmember. I had a new toy arrive today in the form of sand blaster so once I get some aluminium oxide grit I should be able to get all of this much cleaner. It has been a nightmare to clean up with a wire brush. The piece going down in the picture was placed simply to give me a good line to work to when fitting the other pieces. That will be cut away and replaced with a single panel.
Current fleet.
bl1300
Sept 9, 2018 16:56:57 GMT
More work on the right rear quarter today. Unfortunately the repair panel is not quite big enough to encompass all of the rot so I will have to make up a patch to meet it. Even before it's fully welded in and cleaned up though it looks much better for the new section. The repair panel is slightly out in profile so I am going to have to do some fettling now to get it all to look right when it is in. On other notes there was a lot of filler covering a previous repair to the lower quarter. This repair has not been patched over rust. The reason for the filler as far as I can see is the joint has been rolled over and is a good 1/2 inch further in that it should be. This should be repairable with the hammers and dollies to use nowhere near as much filler.
Current fleet.
