pork
Had a little look about it today
Really wanna get this engine going, just so I can have a drive about, and have the old car ‘experience’ 😂
Doesn’t start, bloke had to stick a screw driver between the terminals on the starter solenoid
He also had to put the fuel down the carb as it wasn’t getting fuel to show me engine works
I’ve blown an air gun down the fuel line, it’s clear, so i guess it’s the pump
Put water in it and came straight out the bottom, what looks like the water pump/gasket
The clutch pedal doesn’t return, or feel connected to anything, it’s had a new m/c, but there is a new slave cylinder in the boot, so il be giving that a try
So parts to buy
Starter solenoid/switch
Fuel pump (think it’s just the diaphragm)
Water pump
pork
Should I be looking for parts for a 107e engine then?
(Even though the vin plate says it’s a 100e)
Phil H
Club RR Member Number: 133
Ford 100ePhil H
@philhoward
Club Retro Rides Member 133
It's not a 100E engine now though - is it..
Should I be looking for parts for a 107e engine then? (Even though the vin plate says it’s a 100e) The ford pre-crossflow fuel pumps are all basically the same so provided you get one for a 107E Prefect, 105E Anglia, Mk1 Cortina it should fit - I think even later crossflow pumps fit (Mk1 and 2 Escorts, Mk2 Cortinas) so you should be able to find one. Not a 100E pump though - they have side valve engines and are completely different (I would ignore what the chassis plate says). good luck Cortinaman
Old Fords never die they just go sideways
pork
Cool, cheers people,
All on order 👍
You can buy a rebuild kit if its the glas bowl type pump. Probably better the fitting Chinese curse word
If you go electric pump like I did I have a spare fuel pump blank
pork
You can buy a rebuild kit if its the glas bowl type pump. Probably better the fitting Chinese curse word Yeah, is the glass bowl type👍
jpsmit
Clutch is possibly (probably) frozen to the flywheel. Not a hard job to free it but the engine needs to be running.
pork
Clutch is possibly (probably) frozen to the flywheel. Not a hard job to free it but the engine needs to be running. Cool. How would I go about doing this
pork
Water pump arrived this morning so spent lunch break changing it Fitting on top of old pump disintegrated in removal, So used an old air line hose tail Filled up With water........and it all stays in 👍👍 Wait for rest of parts then hopefully get it running
pork
Oh, and I bought these. Mk1 escort suspension, gonna get a coil over conversion done on them too
spacekadett
F*cking take that Hans Brrix!!
It’s a job to make out as I’m on my phone but I reckon you’ve got an ordinary Prefect that’s had a pre crossflow put in it. The engine looks quite far forwards and the bulkhead doesn’t look like it’s got the 107E recess in it. Regardless it looks like a great project 😎. Mine’s got a Pinto, type 9 and a 105E axle, with the front end being a home brew mix of Escort and Capri bits. There is a thread on here but I think photofucket has eaten the pictures 😩
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
pork
It’s a job to make out as I’m on my phone but I reckon you’ve got an ordinary Prefect that’s had a pre crossflow put in it. The engine looks quite far forwards and the bulkhead doesn’t look like it’s got the 107E recess in it. Regardless it looks like a great project 😎. Mine’s got a Pinto, type 9 and a 105E axle, with the front end being a home brew mix of Escort and Capri bits. There is a thread on here but I think photofucket has eaten the pictures 😩 I’m after a 105 axle, but not many about Any other ways of converting rear hubs to correct stud pattern?
pork
Have read that I can use an axle from a Suzuki rascal/supercarry
Only 1/2’’ wider than the 105e
Anyone heard of doing this?
pork
Jul 29, 2018 11:51:57 GMT
Been doing a few jobs Carb rebuild Accelerator pump was replaced with a bit of metal New pump All cleaned up Fuel pump apart Wrong parts 😕, new one should arrive next week The biggest problem is getting the clutch cylinder out! It’s proper stuck, I’m gunna break the bracket off if I keep going at it, any suggestions
Rob
Jul 29, 2018 13:02:30 GMT
you have a 100e, fitted with a 109e engine and box. it isnt 107e spec. look for a 1600 xflow, it bolts right in.
Jul 29, 2018 13:50:06 GMT
I remember those slaves sticking years ago, try some heat and twisting it back and forth but if that does not work you will need to cut the old slave off each side( pretty easy with an angle grinder, saw a slit or 2 in what is left and knock the remains out.
Jul 29, 2018 15:19:16 GMT
As a fellow old ford owner and having worked quite a bit on my mates 100e I'm enjoying this
pork
Jul 29, 2018 15:22:38 GMT
I remember those slaves sticking years ago, try some heat and twisting it back and forth but if that does not work you will need to cut the old slave off each side( pretty easy with an angle grinder, saw a slit or 2 in what is left and knock the remains out. Think I’m gunna have to cut this out 😬😮
