Apr 27, 2018 16:08:06 GMT
Hi all
i'm just about to start a day van camper conversion on a 2012 Nissan Primastar.
She's an ex Scottish gas van, one owner, full service history with a good spec including electric windows,mirrors,parking sensors,air con,auto wipers etc.
So far I have stripped out the racking and removed the front bulk head.
One quirk of the vans is that they don't come with a passenger seat so I had to source one which was quite tricky as the trim is different to the Renault and Vauxhall variants.
She's going to be a two birth plus a dog with the usual side kitchen layout.
I will be making a few changes to my usual build. The ceiling will be a one piece panel not the usual two piece.There will be no windows in the rear doors so I will be fitted a rear view camera.
She should be complete in 3 weeks, weather permitting.
Cheers - mike
Apr 27, 2018 16:09:42 GMT
Nice one. I really like that color
They are only sold as Renault here in Australia. Are they good van's?
Nice one. I really like that color They are only sold as Renault here in Australia. Are they good van's? hi there I like the colour as well, I get fed up of just doing white are silver. The one after this is metallic black. They are not bad vans, they drive well and are fairly reliable. Cheers - mike
mgmrw
Without wishing to blow smoke up your hoop, the standard and lengths you go to is fantastic.
Some conversions look good, but underneath the vans are grubby, rotten and bodges... That looks properly well done.
Without wishing to blow smoke up your hoop, the standard and lengths you go to is fantastic. Some conversions look good, but underneath the vans are grubby, rotten and bodges... That looks properly well done. Thanks I try my best to buy decent vans to start with but all are stripped and cleaned before I start the conversion. I can't se the point in fitting a nice new conversion on top of 8 years worth of builders muck etc. Cheers - mike
mgmrw
I can't se the point in fitting a nice new conversion on top of 8 years worth of builders muck etc. Cheers - mike That's exactly the point I was making 😎
Hi all Had a steady day on the Nissan today. The wiring loom above the rear doors has been moved. It now runs inside the box section so is no longer seen. I have run all the wiring for the rood lights, added 30mm of insulation and made and fitted the main roof panel. Tomorrow should see the lining panels remade in ply and probably lined with carpet. Cheers - mike
50bhp
May 10, 2018 14:53:55 GMT
Looks really good. I hope to make a dayvan in the not too distant future so will definitely be picking your brains!
May 10, 2018 15:15:53 GMT
Hi all had a steady day today have trimmed the side door step and rear with edge trim. I have remade the linings in 6mm ply where required. The passenger side rear quarter is now fully trimmed and ready to go. Tomorrow should see me making the kitchen unit. Cheers - mike
Hi all got a few more bits done the mains hook up is fitted, the rear doors are fully trimmed and all the lining / insulation is in place. I should be making the kitchen unit tomorrow cheers - mike
May 13, 2018 20:02:49 GMT
Following this with interest, considering building one myself in a Vivaro. Only problem I’ll face is it’ll need to sleep four of us, two adults and two kids and most rock and roll beds are ably big enough for two.
May 13, 2018 20:25:48 GMT
Following this with interest, considering building one myself in a Vivaro. Only problem I’ll face is it’ll need to sleep four of us, two adults and two kids and most rock and roll beds are ably big enough for two. Hi there to sleep 4 you will need the long wheel base, hi roof, which can take a bed for two in the roof. Cheers - mike
May 16, 2018 15:13:22 GMT
Hi all got a bit more done today the main fridge / kitchen unit panels are all made, the fridge is now fitted permanently and the side panel for the wardrobe is made. Whilst access is still good I will be fitting the mains consumer unit,on-board charger and inverter plus all the associated wiring. Cheers - mike
50bhp
May 16, 2018 15:26:20 GMT
How difficult is it to make the front seats swivel? is this something you have done with these vans?
My ideal day van would be either on a citroen dispatch or Vauxhall Vivaro base with a fixed double seat in the back, 2 captains chairs up front that can swivel to face the back and a basic kitchen unit midships, similar to what you have now.
May 16, 2018 16:11:29 GMT
Hi all Got a bit more done the holes for the switches and sockets are now all cut so looks like tomorrow will be a major electrical fitting day. Cheers - mike
May 16, 2018 16:16:23 GMT
hi 50bhp
fitting swivels is easy, finding single passenger seats is ni on impossible.
I fit swivels to the double passenger seats, check my other builds for details.
Cheers - mike
May 19, 2018 13:20:12 GMT
Hi all still plodding along with this one, the mains and 12v systems are now fully installed and tested. I have made the kitchen worktop, its in gloss black laminate not my usual matt black. The hole for the hob is cut and its ready for final install of the hob and worktop. Just waiting for a few bits to arrive before i can finish the kitchen. Monday should see the wardrobe side and front made and fitted, just waiting for final a decision on the final layout from the customer. Cheers - mike
May 28, 2018 22:07:10 GMT
Hi all got a bit more done on the Nissan she's done apart from, remove roof rack, check 240 volt mcbs as the kettle trips out. I think they are both 6 amp even though one should be 16 amp, make and fit the last 2 ceiling panels apply remaining graphics to drivers side machine polish the drivers side and bonnet she's in for mot tomorrow so all going well she will be with her new owner on Wednesday The next one is a Peugeot Boxer with seating for 6 and sleeping for 3. Cheers - mike Cheers - mike
