As the Consul Capri has been put on the back burner 'till I find out what's happening with the emissions limits, I decided to drag this out of the shed.
It's a Williams Lucky Strike, one of 1800 made in 1965.
It's what is known as an electromechanical machine that works with switches, relays & stepper units, no circuit boards or microchips here.
It did work, but having been in storage for 10 years, will need a complete refurb.
At some point in it's life, it's been treated to a new paint job. Hopefully, I'll be able to clean it off & keep the original paint, tried on the back box & it seemed to come off OK.
Started to rebuild the back box, a couple of score reels needed some touching up.
The mech board needed some work, had to clean & adjust all the switches, remove an isolation transformer that the machine had aquired at some time, & replace the 50+ year ols 2 core mains cable with a new 3 core & earth the transformer.
