May 26, 2018 12:05:19 GMT
That front is crazy looking! Any decent tyre shop should be able to dismount the tyres you bought and fit them to the alloys to see how they look for not a great deal of money. Esp if you can go at a quiet time. Bit of swapping about and you'd be done in no time.
@quickrack1 possibly yes, but will the white walls that are bought for the original 5.5inch wide wheel stretch as far as 7.5? I am new at tire fitment... they aren't all 7.5 wide, some are 6.5 and 7 but wanted to get all the options and state the most extreme...
Citroen HY 1962 Toyota CROWN MS75 1972 Toyoya CROWN MS75 1973 Toyota CROWN MS67 1972 Toyota CROWN RS56 1968 Toyota CROWN MS57 1969 Datsun 120a coupe 1975 VW LT31 1995 Volvo XC70 cross country 2007
so this is in for some exhaust works...
This got some daylight, some new friends and a first test drive. Brakes are good, still some electrical things to sort out, breather of the petrol tank seems to be blocked when i tried to fill it up, and some play or bad shocks or something suspensionwise... But kind of busy at the moment with the (lack of) roof on the garage...
Nov 19, 2018 10:05:19 GMT
No real update on the car, but it is back home, as are all the others. And ofcoarse the new roof Still have to sort out the work area, lights and electrics and the storage facilities but getting there...
Nov 19, 2018 10:25:48 GMT
Wow,now THAT is a garage!! When you have some time,please please post a few more pics of the garage. Or thread on other modification or garage life. Awesome job👍👍👍👍
Still working on this, slowly unfortunately... Got some kilometers on it, to the temporary storage and back, and during that, I stopped for some fuel but that didn't go to well. Petrol over my shoes and pants so something wasn't breathing I tought so my attention went to the petrol tank and everything around it. As i didn't find anything obvious at first glance and I want to redo the car completely eventually I decided to just pull the petrol tank out, have a closer look, refurbish, replace hoses and seals,... So this happened this week... not the biggest job but still, is was stuck glued on the booth floor, hoses were difficult to get to, on bolt snapped, all that kind of stuff but... Now do all I can do to it to make it as good as possible again and put it back...
Place where I worked in the late 70's / early 80's had 3 of these parked up side by side for breaking - all were late registered and had relatively little accident damage on each of them but the prices of Toyota parts were astronomic in those days - I don't suppose much has changed on that front so its nice to see a survivor
Last Edit: Apr 4, 2019 13:56:36 GMT by Deleted
I was cleaning up the petrol tank this saterday and was treated to this Now the tank looked to be in good nick on the inside from what i could see so was just going to clean up the outside and put it back. Now i have this... Good way to solve this is to braze is i think but that would leave me with the inside damaged of the heat I think...(?) so then I need to treat the inside aswell..(?) I this right what I am assuming? Or will the inside be just fine afterwards? Or is there a cold way to fix this? Thanks for watching and thinking along
moglite
Club RR Member Number: 144
1972 Toyota CROWN MS67moglite
@moglite
Club Retro Rides Member 144
eurogranada
If your tank is just bare metal from the inside as mine was, than any type of fix involving heat is not really a problem for the tank. It needs to be said that fuel vapours combust easily so that needs to be taken into account.
I did not want to weld or braze my tank as I did not feel comfortable and have no real welding skills. Also pinholes were the least of my troubles, although I had a few! I mostly had rust forming in the tank which kept clogging the filters preventing the car from running. So to address that once and for all I chose to coat the inner of my tank with the POR-15 tank sealing kit. It's a cleaner, prep, final coat set. It's not the cheapest out there (frost sells something similar and cheaper), but it was the one that inspired most confidence when reading up on the coating it leaves behind and the thickness of it. I did try and remove as much rust as I could by shaking pebbles around in the tank before starting the cleaning and coating process.
The por-15 stuff leaves behind a thick durable coating, that can fill pinholes like you've shown with ease. I covered them with tape so any coating could not seep out. I can now fill my tank with confidence and have no funny fuel smells anymore like I had before. It's very doable as well, but you need to account for the process to take a week. Forced drying may help but it is imperative that you work with clean and dry metal.It's been more than a year since I did this and the coating seems to last great judging by the coverage on the pinholes feeling the same as after initial curing.
dikkehemaworst
Club RR Member Number: 16
1972 Toyota CROWN MS67dikkehemaworst
@dikkehemaworst
Club Retro Rides Member 16
If your tank is just bare metal from the inside as mine was, than any type of fix involving heat is not really a problem for the tank. It needs to be said that fuel vapours combust easily so that needs to be taken into account. I did not want to weld or braze my tank as I did not feel comfortable and have no real welding skills. Also pinholes were the least of my troubles, although I had a few! I mostly had rust forming in the tank which kept clogging the filters preventing the car from running. So to address that once and for all I chose to coat the inner of my tank with the POR-15 tank sealing kit. It's a cleaner, prep, final coat set. It's not the cheapest out there (frost sells something similar and cheaper), but it was the one that inspired most confidence when reading up on the coating it leaves behind and the thickness of it. I did try and remove as much rust as I could by shaking pebbles around in the tank before starting the cleaning and coating process. The por-15 stuff leaves behind a thick durable coating, that can fill pinholes like you've shown with ease. I covered them with tape so any coating could not seep out. I can now fill my tank with confidence and have no funny fuel smells anymore like I had before. It's very doable as well, but you need to account for the process to take a week. Forced drying may help but it is imperative that you work with clean and dry metal.It's been more than a year since I did this and the coating seems to last great judging by the coverage on the pinholes feeling the same as after initial curing. What he said ^^^^^^^^^
You have v good written english. Thanks for posting this. Is that your RS200 too?
You have v good written english. Thanks for posting this. Is that your RS200 too? Thanks, and no, it is not mine (unfortunately). The guy in the picture owns it...
moglite
@moglite
I used the Frost kit on my Morris Oxford tank. Can't say how successful it is, as I've not put fuel in it yet. But what I do know, if you spill it on the garage floor - it makes a right mess !! Sloshing it around so it covers all the internal surfaces, with something as unwieldy as a fuel tank is pretty awkward.
eurogranada
I used the Frost kit on my Morris Oxford tank. Can't say how successful it is, as I've not put fuel in it yet. But what I do know, if you spill it on the garage floor - it makes a right mess !! Sloshing it around so it covers all the internal surfaces, with something as unwieldy as a fuel tank is pretty awkward. Haha, I did find that out the hard way as well! The paving at the old house has some stain marks where I was quick to wipe it away, but could not get it out of the texture. In the shed I had a left over bit leak onto my workbench as a test. That went crazy solid and was so strong! Although as said, I used the POR-15 stuff. It's all similar for sure. I have to say that with a pre thought out plan, I found that coating the inners of the tank was far easier than expected. No need to hold it in your hands the entire time. The sloshing around with pebbles was harder and heavier! Mine was a 60 litre tank. During the first hour of curing I kept moving the tank from time to time as to prevent pooling of the coating during early stages of curing.
I am not 100 pct sure but at first I was thinking it had a shine, or blueish kind of coat but with looking at it again it could just be bare metal so no worries about inner coatinf then.
Still, as it is out, coating the inside seems like a good idea but treating the outside I want to do aswell as good as possible so combining the whatever brand coat on the inside I could tin or braze or weld the hole. What would be the best idea.
That said,now I have found one hole I will continue to make the outside skin even better cleaned and who knows uncover more holes...
To be continued
eurogranada
I am not 100 pct sure but at first I was thinking it had a shine, or blueish kind of coat but with looking at it again it could just be bare metal so no worries about inner coatinf then. Still, as it is out, coating the inside seems like a good idea but treating the outside I want to do aswell as good as possible so combining the whatever brand coat on the inside I could tin or braze or weld the hole. What would be the best idea. That said,now I have found one hole I will continue to make the outside skin even better cleaned and who knows uncover more holes... To be continued In my case, the coating was thick enough to fully fill the pinholes. Some even bulged a little on the outside. I sanded that back to just a little bump so I would not compromise how it sealed the hole around the edges. With paint over it, you'd have to look for them to even see. If you are set on brazing, then that would be step one after ensuring the tank is fuel vapour free and safe to approach with a flame. But if the tank inner is not rusty, then I'd not see much need for the coating afterwards.
